Removing Side bumper lights.....
Danijh1
01-28-2004, 11:50 AM
alright you know how on the dodge neons they have them orange side bumper lights?....
alright i got some clear euro ones....and i want to put them on...i tryed to get the orange one off but i dont want to brake it.....
how you get it off... just force it off or what..?
another thing...... can a car go in gear "automatic" if it has no transmission fuild.....? my trans stick tell me that there is no transmission fiuld in my trans.... but the day before it had full.......
we had a snow storm.... and i think my trans has a leak or something......if so i thought it cant go in gear without transmission fiuld...?
Danijh1
01-28-2004, 01:07 PM
Any Suggestions????????????????
ANything???????
MStout
01-30-2004, 01:33 PM
Those corner lenses will be a bitch to take off. The back of them have little cheap metal nut type things like any screw would have, but the threads are plastic. I used a ratchet to loosen it to the point where it wouldnt ravage my fingers twisting it off. And you will probably have to jack up the front end to get under there and be able to see what the hell youre doing. Its frustrating though, so good luck.
NeonStyl
02-03-2004, 04:03 AM
Well, this reply is a little late... but if your still wondering on the side bumper lenses... using a "deep dish" socket helps out greatly on removing / installing those.
I didnt have to jack my car up at all to change those. Just feel around with your fingers to see where light bulb & two metal nuts are.
Also, with your Automatic transmission... you wouldn't want to even try to start the car with no tranny fluid in there, your torque converter would die a gruesome death with no fluid :(. Be sure to use the proper ATF +3 (Type 7176) Chrysler fluid when re-filling and it definitely sounds like you have a leak somewhere... check the tranny pan on the driver's side under the car & the two little hoses that come off the front of the tranny that go to the factory cooler. If those are leaking, that needs to be tended to immediately.
L8R,
