Isuzu 12-bolt Brake Problem - All please readSterling90XJ 01-27-2004, 10:42 AM Having brake adjustment problems in a hybrid situation... The Set-up… ’89 Jeep Wrangler YJ Waggy 44 Front axle w/ discs Isuzu Trooper 12-bolt Rear axle w/ discs New 350 Brake Master Cylinder New Rear Isuzu Rotors New brake lines throughout Proportioning Valve isolated from front brakes The problem… After swapping in the current axles mentioned above, to replace the factory Dana 30 and 35, and a brake bleed, my buddy went out for a test drive. When he hits the brake pedal, the front wheels lock up, while the rear ones just roll. (Test drive on packed snow and ice). At first he thought the factory Jeep master cylinder was shot, and swapped in the current 350 unit. Same results. His next idea, was to try and swap the brake lines around at the master cylinder, thinking that if the rear locked, and the front didn’t, it would at least eliminate the under hood components (ie: Booster) as the culprit. Well, still the same problem. We can’t figure out why the rear won’t lock up with the front. Is there a special way to bleed the Isuzu 12-bolt system? Are we just missing something? Maybe there's an adjustment to make the calipers engage better. Any help will be appreciated. Gary Graham Arctic Offroad Secretary Fairbanks Alaska www.arcticoffroad.com Sterling90XJ 01-29-2004, 10:56 AM Btt mastoras 11-28-2004, 01:07 PM try to adjust the rear pressure regulator. its located in the back. above the rear axle.in the floor not in the car. it is connected with the rear axle Automotive Network, Inc., Copyright ©2012
