Transmisions
jdrumstik
01-26-2004, 01:10 PM
If you don't want all of my rambling move down a couple paragraphs
Im going to be rebuilding a 454 and plugging it into a ElCamino. Im putting my self on a nice budget, since Im going to be doing this over a long time, and I want to do it right. Ive got the next year for the engine, which i will be doing myslef, on a nice budget, above $2000, but its hard to tell.
so I will need a transmision, and I eventually want to dump a supercharger on the 454, I don't know anything about superchargers, but im estimating under 10 ibs of boost.
my estimaiton for the engien is above, 500hp with out the supercharger. and I might be stupid, but if you can nitros charge a supercharged enigine, I'll do that too.
so naturally it will have loads of power, which calls for a more than stock trans.
as long as im replacing something im doing it right.
its got to be
Manual
5 or 6 gears
has to hadle 500+hp
in popular hotraoding this guy had a cuda, with a 408, and a holley 174 super charger making about 550hp, he used a tremc TKOII five speed, thats great, but I might need something stronger and perferably a 6 speed.
eaby had a few ripped out fo corvettes, but I wasn't sure if that was what I was looking for. Any idias? are 6 speeds actually used in the muscle cars world? and surely the stock 4 speed wouldn't work right? any idias are a preciated
PWMAN
01-28-2004, 07:56 PM
What year el-camino?
http://www.keislerauto.com/gm/chevelle.html
:iceslolan
MagicRat
01-28-2004, 10:54 PM
When you get into that kind of power, manuals tend to rip up the rest of the car, (rear ends, exploding clutches etc) Just use a scatter shield.
I don't think any cheaper trans will hold up to well, unless its really been rebuilt well for this kind of use.
The 6 speed from the late model 'Vettes will survive.
Give the Lingenfelter corvette builders a call and see what they use.
But this is big$$$$$$$$$
Doug Nash used to build the 4+3 overdrive 4 spds for the '80's vettes and they are quite strong. Doug Nash also built an aftermarket 5 speed especially for racing and high performance for many years.
Good luck, or save lots of $$$$$$ and use a THM 400.
PWMAN
01-29-2004, 09:13 AM
Clutches exploding? If they can make clutches for diesel trucks that handle 1500 ft/lbs of torque I'm sure there are clutches that can handle 800 ft/lbs from a BBC.
That Keisler transmission link I gave says their tranny will withstand 650 HP, I'm sure they give you a clutch to handle that too.
As for the rear end, well it's your own fault if you put 500 HP to a stock 10 bolt. And if it has a 12 bolt, than beef it up with heavy duty axles, green bearings, Richmond gears, C-clip eliminators, ETC.
jdrumstik
01-29-2004, 11:49 AM
Im working on the engine right now, a 454, I actually don't have an ElCamino, yet. But soon. So I was just looking around. pricing up, Jegs sells a rebuilt 6 speed thats pulled from a vette, its like $3500, which is expensive, its a double overdrive if I remember right, they sell a 4 speed for just 1500 with the same first four gears, no od, but I estimated that as a daily driver, although with low dialy miles, the 2000 extra would eventually make up for in gas, driving a 454.
MagicRat
01-31-2004, 07:50 AM
Yes, 800 ft lbs is more than enough to explode a clutch!!
I have owned, driven and worked on heavy trucks and I have driven race cars.
I know first hand the applications for the two are completely different. Your truck is not wound up to 5000 rpm before dumping the clutch at the green.
It is not the constant torque that blows the clutch, its the load imposed from a hard shift or launch that blows a clutch. For a split second, the load far exceeds that of a big truck.
If one is tries that on a heavy truck, the universal joints on the drive shaft will let go long before the clutch will.
Besides, if clutches exploding were not a serious problem, then why do tech inspection at any drap strip require scatter shields or ballistic blankets on every car that meets or exceeds 12 sec trap time (or whatever the spec is for a particular strip)
Personally, I like my feet intact and I would NEVER race a car like this without a scatter shield. One can drive casually on the street without one, but if thats all one wanted to do then whats the point of 600 hp in the first place.
PWMAN
01-31-2004, 09:10 AM
Not if you get the right clutch, sure any stock or medeocre clutch will blow up but not if you get one right for the job. Like I said about the differentials, if you put a stock clutch in a car making 800 ft/lbs well thats your fault.
I see your point about 5000 RPM then dumping the clutch, but still there are a lot of diesel trucks pulling 12,000+ pound trailers making 1500+ foot pounds-what happens every time they shift or for that matter take off the line in 4WD pulling 6 tons, not to mention the truck weighs over 3 tons itself. And if they can do 2000 RPM, dump clutch with 10 tons and 1500 ft/lbs, well you get my point.
MagicRat
01-31-2004, 04:41 PM
I agree with you. My first post on the subject was advice to get the right clutch, and that it would be expensive, not to avoid one altogether.
Besides, every good race clutch set up I have ever seen uses a steel bell housing that doubles as a scatter shield. Such an item should be considered essential. Again, the point was to either spend the money to do it properly, or not do it at all.
You are saying the same thing.
As for truck clutches, its not the weigh of the truck that makes the difference, its the kinetic energy stored in the rotating parts.
Kinetic energy increses by a factor of 4 times, as the speed doubles. A crankshaft spinning at 3000 rpm has 4 times the amount of force acting on the clutch than one spinning at 1500 rpm.
Therefore, a BBC at 5 grand is likely to have more energy to deliver to the clutch than a truck engine at 1500 rpm.
Finally, truck clutches do not grab the way an auto engine clutch does.
In my experience, the engagement is a bit 'softer' and thus more gentle on the parts, regardless of how you dump the clutch. This is because, in part, a truck clutch disk is actually quite small (12" dia on my Cummins 855) relative to the size and torque of the engine.
PWMAN
01-31-2004, 07:17 PM
I see what you mean about the RPM thing, but I find it hard to believe that weight doesn't make a difference in the stress of the clutch.
My brother has an 02' ram cummins, it has 13'' clutch. I am on some cummins forums and I always here the stock clutches going out on these things when they add mods. My brother(diesel mechanic)says it's because the idiots that drive them always dump the clutch revving it up. You are supposed to let the clutch fully engage giving no throttle, then floor it. His clutch has held fine, and he has a few mods. He took his truck to work on the dyno, 690 ft lbs to the rear wheels.
MagicRat
02-01-2004, 07:34 PM
Thats the way I was taught to drive a big diesel, too.
No throttle, ever, while releasing a clutch from a standstill.
Lots of inexperienced drivers give it some throttle (maybe they are used to cars), and, as you say, its incorrect, and hazardous.
I always maintain if you need to give it some throttle, the starting gear is too high, and you need to use the deep reduction set.
As far as the weight of a vehicle making a difference, I think if one is going to abuse a clutch by winding up the revs and dumping the clutch, the stress is hugh, wether the vehile is 2000 lbs or 20,000 lbs.
But thats just my opinion.
I have heard those Dodge cummins can produce far more power than stock ,and that they are deliberatly detuned, (especially the ones in the '90's) so the trans, especially auto trans will last longer.
PWMAN
02-01-2004, 10:00 PM
Yup.
Yes they are detuned, they are supposed to have 375 HP and 660 ft/lbs. But they can still be turned up plenty more as the internals are WAY more stronger than any other diesel in a pickup.
jdrumstik
02-02-2004, 12:16 PM
so I think I've pretty much got the trans figured out, but its all expensive.
I if was running these gears
1st: 3.28
2nd: 2.14
3rd: 1.57
4th: 1.24
5th: 1.00
6th OD: .76
out of a vette, say through 500 base hp, and lets set the torque equal, what would be a good ratio for a 12 bolt? Whith gas milage in mind, but at the same time street preformance.
And would it be a good idea to buy some 12 bolt out of a heavy duty GM truck at the junkyard, rebuild it, and then have some one smart set the gears so it doesn't seeze?
PWMAN
02-02-2004, 02:04 PM
If you are going to rip out the rear end, don't stick a 12 bolt back in. Go with a custom made Ford 9'', or even a DANA 60. Pack it with 4:10 or 4.56 gears.
If the car comes with a 12 bolt, then just beef it up with better axles, richmond gears, C-clip eliminators, 4:10 or 4:56 gears, ETC.
A truck axle will need to be narrowed for a car, it's not worth the effort to do to a 12 bolt. Now if you grab a DANA 60 out of a 3/4 ton truck, that will be worth your time and money. But there are a lot of places that build Ford 9'' rear ends ready to bolt up to any car.
MagicRat
02-02-2004, 09:42 PM
Most people seem to run the 9 inch Ford when they can afford it.
The 9 inch seems to be lighter, too, than a 12 bolt, at least when I have had to drag them around the shop. The housing is the difference, its welded stampings, not cast steel.
PWMAN
02-02-2004, 09:55 PM
Ahh, the key phrase! LOL
Thats why I didn't get one for my A-body mopar.$$$ Would have been over $2K.
jdrumstik
02-03-2004, 11:56 AM
So It looks like I want some 4:11 gears in the back, which are longer than 4:56 for better gas milage right?
also, it seems like the general trend is get the gears as short as they come. But this won't be to short will it? if im turning .76 through 4:11, through 16 inch wheels (that bout all you can fit under an elcamino if Im right) then whats my RPM at 80mph? I'll do the math, but they can't be too short, is my only point.
btw are there any disaadvantages to a manual trans, cause I can pikc up a trubo 400 for like $800, and this stupid vette trans is $3000 through Jegs.com, not to mention I have to cut up the car to get it in.
PWMAN
02-03-2004, 12:17 PM
Yeah 4:11's will do better on the highway. But that what overdrive is for, most people go with 4:56's when they got overdrive. Are you going to be doing a lot of cruising? Or more drag strip? That answer also depends on whether you should get the TH400 or not.
It's not a matter of wheel size, it's tire size. What tire size will you be running?
jdrumstik
02-03-2004, 02:29 PM
Well, I am thinking like 16 or 17 inch wheels, with a stock looking tire, sorry I don't know tire sizes. I can tell you that I hope to cram 9 inch wides in the back, but I don't know how real that is. btw, the bed will be used to haul my crap to utah when i move out of this joint, so its needs to take some light duty pick up weight, so now low profiles.
I will probably take this to a strip a few times, but mostly for fun, In the end its a daily driver, so gas milage and enjoyment are the two main factors, this is no trailer queen, this thing is going to be hauling the Grass home from Lowes. So I want it to be fun, and automatics are boring to me, So Im going with a vette tranny. Even if it lowers my ets a bit, cause I can't shift.
btw, this is a 454 so 4:56 gears might be a little high? plus gas milage, I live in orange county, gas is comonly over 2 bucks a gallon down here, which makes a financial diffrence when your pulling under 12mpgs. plus, I will probably be doing a Utah trip a couple times a year until i move up there permentatly (going to buy a nice house, and take advantage of thier crappy economy and low land value). So I want good cruizing speeds.
but what it all comes down to is, if its a diffrence between a couple hundread RPM, and a strong 0-60 verses a weak one, I'd take the 4:56 gears.
btw, is hooking a pedal assembly a pain in an automatic car? I just realized that if I have to find a 65 El camino with a manual to start on, thats not rusted through, which might not ever happen.
Sorry for being so wordy! and thanks for being so knowlegeble, thats the cool thing about car, people, a lot of us havn't done too well in shcool, but we understand the physics, and mechanical workings of a car like no other, its strange, how many people are this knowlegeble about Plants?
PWMAN
02-03-2004, 03:24 PM
Width won't matter either when trying to figure out RPM on the highway. Just height of the tire.
Go with 4:10's then.
What cam are you going to run? That make a big difference too.
You would be better off going with Keisler's, they have complete swap to maual trans already set up. No guess work, it's worth the $, but it will be a 5 speed.
BTW, a TH400 is a 3 speed auto.
jdrumstik
02-04-2004, 12:26 PM
I knew that tire width didn't matter. anyways, I'll look into that kieser trans, but what is the guess work with going with the vette trans?
I'm not ver knowlege able about cams, I am going to be taking an enigne rebuild class here at are community college, so I will figure all that out then. I think that I pretty much got it, thanks a lot every one!
PWMAN
02-04-2004, 04:18 PM
Everything will be a direct bolt in. They make the hump with the whole cut for the shifter(that should be welded in though), they give you the bellhousing, clutch, shifter, pedal assembly that will bolt right in. They also give you the tranny mount, as it is different.
Also for the vette trans you would probably have to make a custom driveshaft. There's lots of stuff that you would have to custom fabricate, with keisler's you won't have to do any of that.
jdrumstik
02-04-2004, 04:53 PM
Okay, Pedal assembly and drive shaft did cross my mind, but for some reason I didn't think about it.
Well that kind of sucks, while the kit is priced very reasonably, Just a little over what the vette trans from jegs costs it kind of sucks.
For some reason, the final drive on a 625hp car is .82, and its .78 on a 475hp car. That frustrates me. Also cruizing speeds kind of suck. It looks like I will be going with a 4:11 or maybe even a 3:9 or 3:7 rear end, jsut because the 4:56 has really high RPM, at it maxes out at like 110 mph, but moslty its about fuel economy. But it does show me that the original four speeds really sucked.
PWMAN
02-04-2004, 07:30 PM
Yeah but with the vette trans there is a lot of fabbing that would end up costing you MUCH more in the end, unless you can do it yourself. But the kit will save you time then.
There isn't much difference between .82 and .78. That might be another 5 MPH you top out at.
But yeah thats why I said 4.11's rather than 4.56's once you said about fuel mileage. 3.90's wouldn't be a bad idea.
Yeah the 4 speeds had no overdrive. It's 4th gear was simply 1:1 ratio. The keisler tranny is essentially the same thing as stock except with an overdrive.
jdrumstik
02-05-2004, 11:26 AM
Yeah, well, its actually .68 for the other one, its about 10 mph diffence through out the diffrential gears at about 3000 rpm. I think Im going to be looking for 3.9. Thanks a lot. One more question, it will fit right on to a 454 right?
PWMAN
02-05-2004, 01:48 PM
Yeah just buy the kit for the big block rather than the small block. Thats it.
