1jz Gte????
r34-gts
01-26-2004, 01:23 AM
chasers are 1JZ GTE right
LegacySpeed
02-10-2004, 02:00 AM
Yup. 1JZ-GTE
Alltrac-3sgte
05-27-2004, 07:22 PM
Chaser is the best luxury car evermade because of the new engine that it carrys which is the 1jz-gte (VVTi). this car will smoke any other car 4rm here and wats tight is they use them to drift to
Castrol_XF08
09-03-2004, 08:49 PM
there are 1JZ-GTE which doesn't have VVT-i too
tk_24supra
09-11-2004, 11:44 AM
I am doing an engine swap in my MKIII Toyota supra. I am swaping a 1jz-gte into it and I just bought a R154 tranny for it and I am wondering if I can use the same clutch and fly wheel that comes with the tranny?
I will appreciate anyones help....
tenggis
09-15-2004, 12:03 PM
what exactly is a "VVT-i"? for drifting which engine is better, with "VVT-i" of without? thanks
JWatson
09-19-2004, 07:06 PM
You will need the 1JZ flywheel and bellhousing for the transmission.
Let me know if you need any 1JZ parts....I have these available.
Jeff Watson
Houston,Tx. jwatson@cityscope.net
tk_24supra
09-21-2004, 04:17 PM
Thanks for the help..
tk_24supra
09-21-2004, 05:41 PM
Does anyone know where I can find or buy a chaser shop manual or a 1jz-gte shop manual?
CDUFF7
10-03-2004, 09:02 AM
You could probably find one online but it will be all Japanese. I think you may be able to get one from Australia but not sure. I own a Toyota Chaser Tourer S - that is the 2.5 engine - non turbo (180hp stock). The Chaser Tourer V is the one with the 1jz-gte, mine is a 1jz-ge with VVT-i - Variable Valve Timing intelligence. The car is a very nice 4 door sedan with plenty of power. The regular Chaser (Non-Tourer model) is a 2 litre engine. Hope this helps, maybe I can answer more questions, I live in Japan.
tk_24supra
10-04-2004, 05:14 PM
tk_24supra
10-26-2004, 09:37 PM
I was wondering if I can use the stock clutch that comes with the r154 tranny and would the clutch work on the 1jz-gte motor(twin-turbo)?
rivalbro
03-22-2005, 03:30 PM
Just wondering, how many horses is the 1jz-gte? I know the 2jz-ge is 220hp because I own it, but curious about the twin turbo 1j!
jz-x
03-25-2005, 03:52 AM
i have 1JZ-GTE and as i know it should be 280hp other says 260hp,for me i fell 280HP.
