Keyless
Rachee150
01-25-2004, 12:56 PM
Viewed previous keyless entry thread and found 9 terminals and not 8. This is for a 96. Can you help?
Rachee150
01-25-2004, 02:06 PM
I dont know what happened but nothing in my car works...only the radio... :(:(
KillerKeller_jr
01-27-2004, 10:09 PM
Here is a picture of what your OBDII connector should look like. OBDII Picture (http://img17.photobucket.com/albums/v50/KillerKeller_jr/obd-2.gif) If you study the shape of it compared to yours, you should be able to figure out where the jumpers go. The jumper goes into number 4 & 8. Also you'll notice that there is metal in only certain terminals, can't recall all of them though. I hope this helps!!!
here's how to do it.
Turn ignition switch "off"
Using a fused jumper, juper data line connector terminal 8 (blk/wht) to terminal 4 Blk close all doors
turn ignition switch "on" door locks cycle
press and hold lock and unlock button on one transmitter alter a 30 second delay the doors will lock and unlock
repeat step to program extra transmitters
do not turn off ignition, if switch is turned off the first transmitter will become inoperative.
disconnect jumper from DLC
that works
i did it.
rg4541
02-07-2004, 01:29 AM
Same procedure worked for my 1995 Aurora, saved the dealership fee, they wanted $50!!!
