Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Nonspecific
Old 01-25-2004, 11:23 AM   #1
jodiemeglio
jodiemeglio Normal reputation
Send a message via AIM to jodiemeglio
strange vibration, someone help me!
a few weeks ago i'm driving my 1990 jetta down the highway and it starts making this strange rubbing noise from the drivers side front. i think, hey no problem! i'll throw a new wheel bearing in, no biggie. so since then i've replaced- the wheel bearing, whole shaft(both cv joints), and last night i swapped transmissions thinking it was the differential bearing. the only thing left is the ball joint but that would make a rubbing sound. someone please help!!!
thanks a lot
jodie
jodiemeglio is offline   Reply With Quote
Old 01-25-2004, 03:26 PM   #2
mechy1barry
mechy1barry Normal reputation
Re: strange vibration, someone help me!
1/swap wheels about.
2/check brakes.
mechy1barry is offline   Reply With Quote
Old 01-25-2004, 05:14 PM   #3
jodiemeglio
i rotated the tires. brake pads are brand new and the rotors have no funky spots in them. maybe the caliper?
Old 01-26-2004, 02:44 PM   #4
mechy1barry
check on the splash guard around disk,may be rubbing somewhere.otherwise check pads are located correctly, and shims/springs not out of alignment.
Old 01-27-2004, 04:42 PM   #5
renrut
renrut Normal reputation
Send a message via AIM to renrut Send a message via Yahoo to renrut
Lift the front end off the ground, chalk the rear tires, put the car in neutral and spin the tires. Thats what I did with my fox and found the rotors were rubbing against the splash shields. It also may be the rotors may not have any weird spots on them but they may be slightly warped. Swap the rotors check to see if the noise went with the rotor to the other side.
renrut is offline   Reply With Quote
Old 01-27-2004, 09:00 PM   #6
jodiemeglio
thanks for the help, i'll try that asap...well as soon as i can get the thing started. my starter isn't working, hopefully i didn't kill it putting the transmission in.
Bookmarks
Google
Web AF
