shudder and noise in rearend 1991 rodeo
skgirl
01-23-2004, 06:02 PM
When I accellerate there is a little bit of a shudder, just 2 little shakes. Also there is a single clunk noise that comes from the back. The more obvious problem is when I go to slow down it feels like the rear end is tugging and it makes a deep noise, not grinding... its hard to explain. It affects my rpms, but my oil pressure does not change. Does anyone have any idea what might be wrong?
amigo-2k
01-23-2004, 07:08 PM
shudder may be plug wires, maybe the fuel filter.
Your rear end stuff sounds like your rear diffy has some problems or maybe is low on oil.
-Ryan
Dan106
02-27-2004, 06:07 PM
Try checking the Carrier Bearing which is located on the driveshaft. Mine shuddered when I took off, then would be fine when I got up to speed. U will have to pull the driveshaft, and the 2 bolts holding the carrier bearing bracket on. Check to see if you can feel or hear a grinding in the bearing.
fergmonster
02-29-2004, 09:01 PM
the carrier bearing is the correct fix for this, it is pretty common if you have ever towed anything with this vehicle. also they are dealer only items.
