Someone Please Help!!!
blkcavi02
01-23-2004, 02:19 PM
Does Anyone Know How To Get The Ebrake Handle Off Of A 2002 Cavi I Tried Many Sizes Of Allen Keys Where There Is A Little Hole And It Doesn't Feel Like Any Of Them Are Gripping Anything. I Also Tried To Pry It Off And It Isn't Budging. And Of Course The Chevy Dealer Told Me It Doesn't Come Off But I've Heard That Before On A Lot Of Things! If Anyone Has Any Ideas I Would Appreciate It Thank You. Stacy
algoesfast
01-23-2004, 03:57 PM
Did you look into the hole with a flashlight? I'm thinking that there may be a pin pressed in there. In that case I would say if you are that determined try to hold it someway and beat that sucker outa there. Good luck!
DragonWalker
02-07-2004, 05:55 PM
Or it could be a Torx bit that you need to use
Overtime
02-08-2004, 11:21 PM
After checking with a flashlight, if it is perfectly round, it is probably a pop rivit. If so, then you have to drill it out....
what? you drilled it out and now you want to put it back in? :banghead:
blkcavi02
02-09-2004, 10:09 PM
thanks guys for all your help i guess i'm going to try to drill it out or cut it off cause nothing else will work thanks again i really appreciate it. stacy
