Help if anyone cantyberious 01-22-2004, 10:06 PM I have a 1990 Z-24 cavalier , It has this clunk when ya turn and vibrates badly , I have replace everything once if not twice ,had about twenty different shop look at it ......no one I mean no one can tell me what it is ....I need help it not the normal clunk's i guess ,so need advice out side the box so to speak ........or sugestions :o( I dont wanna get rid of it ,but I'm clueless what am I to do ,when no one can tell ya ? thank Tammy heatherannie22 01-22-2004, 10:18 PM What have you replaced? CV? Have you had the stabilizer arm checked? What about the bearings? Tie rod ends? Does it pull to either direction while going down the road? Could be something with the brakes too, like a caliper. Sounds like a CV though, if you haven't had that replaced already. tyberious 01-22-2004, 10:28 PM What have you replaced? CV? Have you had the stabilizer arm checked? What about the bearings? Tie rod ends? Does it pull to either direction while going down the road? Could be something with the brakes too, like a caliper. Sounds like a CV though, if you haven't had that replaced already. I have done the axles twice, rack and pinon twice strut & shock three times ,ball joints 3 maybe 4 times now , replaced the knuckles ,motor mounts ,some top to the rear shocks just in case but clunk is up front .done the brake rotor caliper twice now ,lord everything that up there ...i'm so stump and the shop guy just say thatthey just cant find it ! i had the frame check to .....everyone says everything look and feels good .but it still clunks :( i so sad about it ,just want it right Tam heatherannie22 01-22-2004, 10:36 PM Let me ask around a little, other than those things, I have no idea. When you say axles, do you mean the CV joints? tyberious 01-22-2004, 10:40 PM yes cv/trans axles , I would apperciate any help you come up with , I don't know what I am suppose to do when the shop guy just give up :o( and tell ya they just don't know ! heatherannie22 01-22-2004, 10:44 PM I have a friend thats a mechanic, and another friend that does alot of car work on the side and knows a lot, so I'll ask around. I'm at work right now, and I get out at 11, so I won't be able to reply till tomorrow at around 3:30, but I'll see what I can come up with. tyberious 01-22-2004, 10:48 PM thanks :) Z24 for life 01-23-2004, 02:20 AM try the front coil springs and the wheel bearings tyberious 01-24-2004, 09:08 AM Front coil spring ? i'm not familar w/ that maybe I call it something else :O) Is that the strut spring ?????? I've done the wheel bearings Automotive Network, Inc., Copyright ©2012
