car run inegalborty 01-21-2004, 03:39 PM Hi my car is an 1987 towncar signature edition and it start correct but after that it run like that it speed's up then down then up then down then it goes on like that till it get hot then it goes like normal but my car lack of power it not like usual. so the erg valve as been change the emmision valve too the fuel filter and the air filter too . and it take more gaz then usual So can you tel me what wrong??? i'd really apreciate any information thank Towncar 01-22-2004, 12:34 AM I'm not too familiar with the 1987. Your description sure sounds like a carburator problem to me. Anyone else have an opinion? borty 01-22-2004, 01:10 PM eeee it is full injection. so any other idea???? and one of my friend told me that it might be cause i've change my batterie and the car computer is uncalibrated. Thank in advance Towncar 01-23-2004, 12:20 AM If that's actually the case, which I have heard of, it should "learn" normal running conditions in about 50 miles. When I changed my battery I left a 12volt power supply to the car with jumper wires and a charger. borty 01-23-2004, 03:27 PM ok than i'm going to try that! ltdltc 01-24-2004, 04:10 AM If the Idle is going up and down, the first thing you want to look at is the IAC. The Idle Air Control Motor or Valve is on the backside of the throttle body, it adjust the air going into the engine to control the idle. The problem is this part gets filled with junk from the engine and causes it to malfunction. It's a easy part to change and only costs $30 someodd dollars from AutoZone. You could also try cleaning it. It is held on to the throttle body by 2 screws (don't know if they were bolts or screws) and a connector at the end. Good Luck Automotive Network, Inc., Copyright ©2012
