B16 swap problem please help!
Aaron91ef9
01-20-2004, 09:14 PM
I just swapped a b16a1 into my 91 civic si and everything seems to be working fine except when the engine gets to operating temp. the idle starts jumping from about 1300 rpm - 700 rpm when it idles. Does anyone know what to do to fix this? I have been told that I might need to adjust my idle adj. screw on the throttle body, but Im not sure. Please help!!
thanks!
leolo007
01-21-2004, 02:49 PM
does your check engine light come on? I cant help you but I sorta have the same problem, except idle is fine but check engine light comes on :dunno:
Aaron91ef9
01-21-2004, 04:59 PM
No, my check engine light doesn't come on.
94civic b16
01-26-2004, 02:30 AM
your idle air control valve is messed up its ubder your intake manifold thats teh prob
Jszy
02-11-2004, 02:18 AM
Sounds like ECU to me...
defman
02-11-2004, 02:22 PM
I had the same problem, it turned out to be my idle air control valve
19B16CRX91
02-12-2004, 07:53 PM
ihad the same problem with my b16 '91 CRX,and i fixed my idle control valve under the throttle body and the idle still keeps jumping around,anyone else have a problem like this and know what to do?
19B16CRX91
02-12-2004, 07:54 PM
and my check engine light is on...
