Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Primera/G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 01-20-2004, 06:11 PM   #1
Euan
Euan Normal reputation
Clutch fitting 4x4 Primera (G20) How?
Hey if there is anyone out there who has any experience with the clutch on the 4x4 model or has removed the engine (engine has to be removed to get at clutch) I would be very greatful for some advice. I am concerned mainly about uncoupling the engine from the drive train to the rear wheels. I dont want to screw anything up with the fluid coupling. I would really like to know about pitfalls and things to watch for when removing the engine from this particular model.
CHeers.
Euan is offline   Reply With Quote
Old 04-29-2004, 01:48 AM   #2
mcguiver7
mcguiver7
Send a message via AIM to mcguiver7
4x4 primera/g20?????? never made such a model. unless someone customized it. and they had to of gone through a shitload of fabrication considering modifying a drive shaft around the gas tank and that would also require using a pulsar gtir tranny and flywheel.
for my install the only thing i had trouble w/ was getting the axles out of the hub. few people said take the suspension apart at the upper linkage but i just found taking the control arms off to be easier. working the tranny out was a bit of a pain too but it wasnt too bad. other than those problems it should only be a half a day job.
matt
mcguiver7 is offline   Reply With Quote
Old 05-02-2004, 06:14 AM   #3
thaa
thaa's Avatar
thaa
Send a message via ICQ to thaa
Re: Clutch fitting 4x4 Primera (G20) How?
matt
the primera was made and the p12 is still made with 4x4 as an option in japan.
'96 Primera P10
Formula Classic's 17's wrapped in 205/40ZR17
Do you like bananas? I got her number! Now, how do you like them bananas?
thaa is offline   Reply With Quote
Old 05-02-2004, 01:30 PM   #4
mcguiver7
mcguiver7
oh i see so the p12 was 4x4.
Old 05-05-2004, 04:11 AM   #5
krazeguy
krazeguy
Send a message via MSN to krazeguy
There are P10s and P11s in 4WD config.
HNP10 / HNP11
They are called T4's and can usually only be found in Japan and here in New Zealand.
http://www.krazeguy.com
krazeguy is offline   Reply With Quote
Bookmarks
Google
Web AF
