Turn Signal indicators stopped workingsanxxx 01-20-2004, 12:10 AM Turn signal indicators all stopped working suddenly. I checked the fuse and it is alright. I don't think all 4 bulbs can go out simultaneously. What else can be wrong. sheldonbailey 02-03-2004, 08:53 AM I had the same problem with my 1995, I found that under the hood drivers side there is a set of fuses, the two fuses under there will say "DLR" and "Hazzard", the "Hazzard" which is a 10amp fuse for some reason it reads 12volts when the car is not running but as soon as I start the car the volts would drop and the signal lights & hazzard would not work. So I took a 12volt source from the battery and put it to the side which feeds 12volts to the "hazzards" and plugged the fuse back in. Solved my problem. Hope this Helps Automotive Network, Inc., Copyright ©2012
