Program Toyota Master KeyPages :
[1]
2
Jeff34 01-18-2004, 09:12 PM Is it possible to program an extra master key myself? Rather than paying the dealer 50 bucks to do it. Since I posted this message I called a friend that worked with Lexus. Gave him the key and SUV. One of his tech guys had to flash the transponder in the key to activate. this was accomplished by inserting it into a key programmer. Once the key was flashed or activated the technician connected the OBD II analyzer to the Sequoia's system to program the key. Could not do this myself. Still had it done for $ 0.00 though. It pays to have friends in the car business. ToyotaTech 02-13-2004, 03:44 AM In key programmer? I don't think so, the only way to program the key is with the scantool only lexus and Toyota have the same scantool. MYSEQUOIA03 02-14-2004, 12:24 AM There are 2 ways to program the transponder key depend on your model. So far you can program ONBOARD which mean you don't need the programmer. The only you need is current master key (Black one) and the blank transponder key. The transponder key for 2003/2004 has a different chip from 2001/2002. If your Sequoia is 2001 or 2002, you can purchase the blank key from eBay $19. bring this to any Walmart or hardware store. They can cut this for you then you can program your own. msjulian 02-27-2004, 05:19 PM There are 2 ways to program the transponder key depend on your model. So far you can program ONBOARD which mean you don't need the programmer. The only you need is current master key (Black one) and the blank transponder key. The transponder key for 2003/2004 has a different chip from 2001/2002. If your Sequoia is 2001 or 2002, you can purchase the blank key from eBay $19. bring this to any Walmart or hardware store. They can cut this for you then you can program your own. I have the key and it is cut now I need to program. What is the correct sequience? I have heard that it is called the brake dance and you have to use the brake and gas pedal. Can anyone send me the correct way to do this and maybe how to clear the computer in case it is full??? Thanks a ton!! Mike Julian MYSEQUOIA03 02-28-2004, 02:01 AM I have the key and it is cut now I need to program. What is the correct sequience? I have heard that it is called the brake dance and you have to use the brake and gas pedal. Can anyone send me the correct way to do this and maybe how to clear the computer in case it is full??? Thanks a ton!! Mike Julian Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 msjulian 02-28-2004, 04:10 PM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 I have a 2001 and the master key. I think all I need is the programming instructions. I would also like to be able to clear the computer of all other key codes if possiable. My address is msjulian@sigecom.net Thanks a ton!! Mike renman 03-03-2004, 11:24 AM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 Could you please email me the PDF file for how to program the transponder key for the 2004 Sequoia? My email is r11garcia@yahoo.com. Thanks a lot! stulloss 03-05-2004, 06:27 PM I just purchased a 2001 Sequoia. The only key available to me was the grey master key. Here is my problem, the dealership says they have to have a master key (black one) to create another key. Without that they say I am screwed and have to buy a new computer $1000-$1500. They gave me a number to call Toyota National and told me they will purchase the new computer. Toyota National tells me the 2001 models have re-programmable computers. I have called 4 dealerships in the area and none can confirm that it is a reprogrammable computer. Prices for a new master key run $35-$55, the programming if I had a master key would be $30-$75 depending on the dealership. Does anyone have any better, cheaper solutions or ideas for me to explore? digitaltinker 03-07-2004, 08:44 PM Hi, I have a 2003 Sequoia and wanted to get an additional key. Could you please also email me the PDF file for how to program the transponder key (to digitaltinker@hotmail.com) ? Also, could you possibly tell me if it is possible to program an additional remote (# HYQ12BAN) for the Sequoia. I saw the other post but it looked like that was for a Tacoma. I want to buy an additional remote on ebay but wanted to make sure that I didn't need to go to the dealer $. Many many thanks in advance. sequoia01 03-17-2004, 05:32 PM Instructions for programming a transponder key. Prerequisites: blank transponder key (eBay.com - $20). pre-programmed master "black" key for the vehicle. Programming spare keys: for 1998 to 2002 1.. Copy the cuts of the original working key onto the appropriate transponder blank. 2.. Enter the car and close all of the doors. 3.. Simultaneously depress and release both the brake and accelerator pedals. 4.. Within five seconds, insert a working pre-programmed key into the ignition cylinder, and turn to the "on" position. 5.. Within fifteen seconds of turning the ignition, depress and release the accelerator pedal five times for a primary key. (Depress and release four times for a valet key.) 6.. Within twenty seconds, depress and release the brake pedal six times for a primary key. (Depress and release only times for a valet key.) 7.. Turn the ignition to the "off" position and immediately remove the key. 8.. Within ten seconds of removing the key, insert the new key and turn it to the "on" position. 9.. Within ten seconds, depress and release the accelerator pedal once. The security light will then flash for 60 seconds and then turn off. When the security light stops flashing the programming should be complete. 10.. Start the vehicle to verify that programming was successful. FOR 2002+ 1.Make sure all doors and windows are closed. 2.Insert master key into the ignition cylinder. 3.Cycle the ignition cylinder from ON to OFF 5 times. 4.Open and close the driver side door 6 times. 5.Remove the master key and insert the new duplicate key. 6.DO NOT TURN THE IGNITION CYLINDER ON 7.The new key will be registered after 60 seconds.The THEFT light on the dashboard will go out,indicating that programming has been completed. "some 2002 will work using the 1998+ programming." sahan32000 05-21-2004, 03:03 PM hi ihave land cruiser and i need to program my blank key please what i need to do it ToyotaTech 05-22-2004, 02:52 AM OK what if the key program is closed by the port or dealer? because in the scan tool setting u have to close the program that programs the keys? tenunderpar 06-07-2004, 07:10 PM A couple of things bother me in my so far unsuccesful attempts to program a new transponder key for my '99 Avalon. The security light never stopped flashing! Should I have had my selt belt fastened? Should my sunroof have been closed? I could go on, but I'm stopping any further attempts until I find out if there is a limit to how many times I can try. Instructions for programming a transponder key. Prerequisites: blank transponder key (eBay.com - $20). pre-programmed master "black" key for the vehicle. Programming spare keys: for 1998 to 2002 1.. Copy the cuts of the original working key onto the appropriate transponder blank. 2.. Enter the car and close all of the doors. 3.. Simultaneously depress and release both the brake and accelerator pedals. 4.. Within five seconds, insert a working pre-programmed key into the ignition cylinder, and turn to the "on" position. 5.. Within fifteen seconds of turning the ignition, depress and release the accelerator pedal five times for a primary key. (Depress and release four times for a valet key.) 6.. Within twenty seconds, depress and release the brake pedal six times for a primary key. (Depress and release only times for a valet key.) 7.. Turn the ignition to the "off" position and immediately remove the key. 8.. Within ten seconds of removing the key, insert the new key and turn it to the "on" position. 9.. Within ten seconds, depress and release the accelerator pedal once. The security light will then flash for 60 seconds and then turn off. When the security light stops flashing the programming should be complete. 10.. Start the vehicle to verify that programming was successful. FOR 2002+ 1.Make sure all doors and windows are closed. 2.Insert master key into the ignition cylinder. 3.Cycle the ignition cylinder from ON to OFF 5 times. 4.Open and close the driver side door 6 times. 5.Remove the master key and insert the new duplicate key. 6.DO NOT TURN THE IGNITION CYLINDER ON 7.The new key will be registered after 60 seconds.The THEFT light on the dashboard will go out,indicating that programming has been completed. "some 2002 will work using the 1998+ programming." bobbason 06-24-2004, 12:08 PM I just purchased a 2001 Sequoia. The only key available to me was the grey master key. Here is my problem, the dealership says they have to have a master key (black one) to create another key. Without that they say I am screwed and have to buy a new computer $1000-$1500. They gave me a number to call Toyota National and told me they will purchase the new computer. Toyota National tells me the 2001 models have re-programmable computers. I have called 4 dealerships in the area and none can confirm that it is a reprogrammable computer. Prices for a new master key run $35-$55, the programming if I had a master key would be $30-$75 depending on the dealership. Does anyone have any better, cheaper solutions or ideas for me to explore? I just got a toyota sequoia 2002 with just the grey key. Were you ever able to get a new black master key reprogrammed? If so you can you send me the details. Thanks... block3 06-25-2004, 10:10 AM I am a locksmith and run into this all the time, never, never go to a dealer for key problems with a Toyota or Lexus, unless you want to pay out the ass. On the 01-02 Sequoia, the immobilizer system is built into the ECU. Luckily for you they are resetable using a scan tool with the proper software. You should never have to replace the computer on any Toyota/Lexus when you lose keys. All of them can be reset to accept new keys (most dealers don't know this, so don't ask them). Some can be done with scan tools, some require removal of the ECU or Immobilizer unit and can be reflashed to accept new keys. I do it all the time, I reflash them for my local dealers and auctions, this is a hell of alot cheaper than replacing the ECU at $1100+ I suggest getting in touch with a local locksmith (Must be an auto specialist) that has the required software or you could pull out your ECU (takes about 10 minutes) and send it to me and I can reflash it to accept new keys. Once this is done you can add more yourself using the onboard programming method. If interested in this service you can visit my website at http://www.hightechcarkeys.com david_vu04 10-05-2004, 05:14 AM This might be off topic a bit, but i need help Programing a blank Master key for Lexus Is 300 bretbowman 11-19-2004, 12:09 PM My wife and I just purchased a 2002 Toyota Sequoia Limited 2WD. I wanted to see if I could get anyone to send me the procedure for the following: 1. Clear all from computer in case it's full 2. Add/Program Keyless entry remote control 3. Add/Program Blank Transponder key into a Master copy key 4. Add/Program Blank Transponder key into Valet copy key 5. Difference in procedures for different year models 6. Similarities to other model Toyotas (such as Tacoma, etc.) If someone can send me these instructions (preferrably the .pdf from Toyota), I can post these on my permanent website with a easy to remember URL for anyone to refer too. I'm seeking assistance with this for my own toyota, but would love to be able to assist or help others any way that I can. I have virtually unlimited storage space and a generous 768k upload speed with static ip, so hopefully this is a good asset to offer. As always thanks in advance to any who can assist. Your assistance NEVER goes unappreciated by us in this forum. Sincerely, Bret Bowman bretbowman@yahoo.com sandmanva 12-12-2004, 10:34 AM I just bought a 05 Sequoia. I misplace my keys alot, so my solution has always been to have extra sets. Is it possible to program more than 4 keys for the truck? I just paid a boatload of cash at the dealership to program five keys and was then was told only fours keys were possible. Now I have a cut key that will not start the truck. With Nissan it was easy to buy remote off of ebay and program them myself. Toyota makes it much harder in 05. Can anyone send me the sequence for the keys and the remotes for future.Is it as hard as the dealer makes it out to be? lol@cox.net thnkas dave Camry02LE 03-04-2005, 05:22 PM Instructions for programming a transponder key. Prerequisites: blank transponder key (eBay.com - $20). pre-programmed master "black" key for the vehicle. Programming spare keys: for 1998 to 2002 1.. Copy the cuts of the original working key onto the appropriate transponder blank. 2.. Enter the car and close all of the doors. 3.. Simultaneously depress and release both the brake and accelerator pedals. 4.. Within five seconds, insert a working pre-programmed key into the ignition cylinder, and turn to the "on" position. 5.. Within fifteen seconds of turning the ignition, depress and release the accelerator pedal five times for a primary key. (Depress and release four times for a valet key.) 6.. Within twenty seconds, depress and release the brake pedal six times for a primary key. (Depress and release only times for a valet key.) 7.. Turn the ignition to the "off" position and immediately remove the key. 8.. Within ten seconds of removing the key, insert the new key and turn it to the "on" position. 9.. Within ten seconds, depress and release the accelerator pedal once. The security light will then flash for 60 seconds and then turn off. When the security light stops flashing the programming should be complete. 10.. Start the vehicle to verify that programming was successful. FOR 2002+ 1.Make sure all doors and windows are closed. 2.Insert master key into the ignition cylinder. 3.Cycle the ignition cylinder from ON to OFF 5 times. 4.Open and close the driver side door 6 times. 5.Remove the master key and insert the new duplicate key. 6.DO NOT TURN THE IGNITION CYLINDER ON 7.The new key will be registered after 60 seconds.The THEFT light on the dashboard will go out,indicating that programming has been completed. "some 2002 will work using the 1998+ programming." Thank you for the instructions. I just bought a 2002 Camry LE V6, but only have one black key (I assumed its the master key). Will this instruction work for my car? I was told you can only program up to 3 keys. How do I erase all previous keys, and then add my new one. I did purchase a transponder key off Ebay, but their instructions don't work. I asked for alternate instructions, but just have no luck. My dash do not have a THEFT light, so I assumed I should use the 1998-2002 instructions. But how do I reset all previous keys? I will appreciate if you can e-mail me the instruction in PDF file, kietman35@gmail.com. Thanks in advance for any help you can provide. GuyF 05-25-2005, 12:31 AM I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Would you be able to send me the pdf to program a key for a 2001 sequoia? Thank you very much GuyF 05-25-2005, 12:38 AM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 Could you please send me the procedure to program a key for a 2001 sequoia at gferraro@swbell.net? Thank you very much OkHumourMe 10-25-2005, 10:40 AM Instructions for programming a transponder key. Prerequisites: blank transponder key (eBay.com - $20). pre-programmed master "black" key for the vehicle. Programming spare keys: for 1998 to 2002 1.. Copy the cuts of the original working key onto the appropriate transponder blank. 2.. Enter the car and close all of the doors. 3.. Simultaneously depress and release both the brake and accelerator pedals. 4.. Within five seconds, insert a working pre-programmed key into the ignition cylinder, and turn to the "on" position. 5.. Within fifteen seconds of turning the ignition, depress and release the accelerator pedal five times for a primary key. (Depress and release four times for a valet key.) 6.. Within twenty seconds, depress and release the brake pedal six times for a primary key. (Depress and release only times for a valet key.) 7.. Turn the ignition to the "off" position and immediately remove the key. 8.. Within ten seconds of removing the key, insert the new key and turn it to the "on" position. 9.. Within ten seconds, depress and release the accelerator pedal once. The security light will then flash for 60 seconds and then turn off. When the security light stops flashing the programming should be complete. 10.. Start the vehicle to verify that programming was successful. FOR 2002+ 1.Make sure all doors and windows are closed. 2.Insert master key into the ignition cylinder. 3.Cycle the ignition cylinder from ON to OFF 5 times. 4.Open and close the driver side door 6 times. 5.Remove the master key and insert the new duplicate key. 6.DO NOT TURN THE IGNITION CYLINDER ON 7.The new key will be registered after 60 seconds.The THEFT light on the dashboard will go out,indicating that programming has been completed. "some 2002 will work using the 1998+ programming." Great Postings Folks, I have a question on the instructions above... DO you have to have the MASTER key to program the new key? OR... Can I program a new Blank tansponder from the Grey Valet key? And I f it is possible to program a new Master key fromt he Grey key... then is this a Real master key or is it really a Clone? Thanks in advance P. cvayala 12-06-2005, 01:19 PM I registered just to confirm that the procedure worked on my recently purchased 2002 Camry LE V6. By the way, the reason you need a master key is to confirm to the vehicle that you are the owner. Or another way to say this is to prevent a valet (or whoever you give the grey key to) from programming a master key for your car. madhouze 12-06-2005, 07:48 PM It has been quite a long time since people wrote in here, but i will try my luck anyway: I purchased a 2005 toyota Matrix XR. Installed Viper 791VX with remote start, and now bought a few blank transponder keys so i can use the remote start. I have found over the net a few instruction for programming the keys, but cannot complete any of them. PLEASE! advise? Thanks, Ohadidan@gmail.com hopphan 08-20-2006, 10:58 PM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 Hi Mysequoia03 The post too old now, wish you still read it and help me with this. I had sequoia03 and just bought and cut the new key, but don't know how to programming, would you please share to me the pdf file so I try to program the new key. (hopphan@yahoo.com) Thank you sohail43r 10-16-2006, 11:50 AM I have lost my Master key of toyota camry 2001 4 cyl. i have purchase new blank key from toyota and make cut , i'm able to open all door but engine is not working. key need to program. or some other idea to run my engine . thanks sohail43r 10-21-2006, 10:29 PM I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Would you be able to send me the pdf to program a key for a 2001 sequoia? Thank you very much hello , I have lost my all master keys,:banghead: but I have one duplicate which can open all doors even can move switch bt engine does't start. i have purchase new blank key from ebay, could you guide me how to program new key without master .... as i dont have nay master..:rofl: i make cut similar to normal duplicate key... thansk my email : sohail43r@hotmail.com skillzunlimited 01-26-2007, 02:30 PM Can u email those directions to me as well? salvin@excite.com jws13 01-27-2007, 07:24 PM Can someone tell me how to program the keyless remote for a 2005 Sequoia? skillzunlimited 02-02-2007, 01:19 PM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 would u email the directions to skillzunlimited@comcast.net Thank you dealerkeys 05-09-2007, 09:03 AM If you have lost your master keys and need help. Just email me and I can reset your computer for you. Abalazo 05-25-2007, 11:39 AM If you have lost your master keys and need help. Just email me and I can reset your computer for you. Dear Friends, I own a 2003 Landcruiser I have only the valet key, I bought on eBay A nEW mASTER KEY WITH THE REMOTE Panic and opening doors feauture, I will like someone to help me program this key. I will appreciate if someone can send me the PDF file and I will like to know if this can be done with the valet key I have. Warmest regards, Ruben ruben@tribaldos.net syclone11208 06-03-2007, 06:00 PM can someone email (syclone11208@yahoo.com) me a step by step, how to program a new master key for a 2004 toyota sequoia. THX...... alisarwar 06-25-2007, 09:43 PM Just curious, If You lost one of your keys (Master or Valet) and someone finds it......... Then he/she can have easy access to your car. Is there a method to change the starting code on my Master key. so that my stolen key does not work if someone tries to use it on my car MudCruiser 08-16-2007, 03:11 AM Hi Gang - I am a newbie so please be patient....Can anyone help me - I am in Australia and have just purchased a 2000 Landcruiser 100 series GXL Wagon. I only have a "slave key" (but it opens all locks including the glove compartment). Mr Toyota sold me a new key, but then said he could'nt program it as I only have a "slave" not a "master". His solution, a new ECU approx $ 1000! Yeah, right.......can anyone help......... tiptai 09-23-2007, 04:29 PM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 Can you sent a PDF file from rom TOYOTA dealer manual for me at tippatai_tour@hotmail.com I have some question, My car is toyota innova in first year about 2005 i can use this manual for program my immo key and my remote(keyless) both together in one. (my key like camry) Thankyou verymuch ps. my key photo in here http://www.pantip.com/cafe/ratchada/topic/V5844192/V5844192.html#13 chuckf 09-28-2007, 06:28 PM Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 I have a 2004 Toyota Sienna. Will your instructions work for my vehicle as well? If so, send to chuckf *at* usfamily.net sam1965 11-25-2007, 05:57 PM 2001 sienna xle lost master key only one key that dosn't start the van any help ... thank you oballout@comcast.net sservet 12-21-2007, 09:30 AM would you send me the pdf file to my e-mail Thanks...My mail is servetozagac@yahoo.com sservet 12-21-2007, 09:32 AM Hi..I have a 2003 Toyota Avensis 2.0 I bought a new key fob from e-bay. But I dont know how to program it. Can anyone help me...? My mail is servetozagac@yahoo.com jetta4 12-27-2007, 09:27 AM could you email me the instructions to program a new key ( 07 camry) to schmidts101@aol.com Thanks stclairtech 01-02-2008, 05:51 PM I too would like to have the pdf file emailed to me to program the keys for my '04 4-Runner. Thanks in advance. email to: stclairtech@bluefrog.com chepemoco1 01-08-2008, 06:05 PM I just bought an additional master key(black) for my 2003 sequoia SR5 at the dealership. The dealer wants $110 for the programming. I would like to know if I can program it myself? and How? Thanks. please e-mail instructions to chepemoco1@netzero.net mazoner2005 01-25-2008, 10:10 PM i have no master key and need to program a new can someone help mazoner2005@aol.com mazoner2005 01-25-2008, 10:15 PM please help no master key need to program new one my email mazoner2005@aol.com mazoner2005 01-25-2008, 10:17 PM [quote=GuyF]I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Would you be able to send me the pdf to program a key for a 2002 camry? Thank you very much email mazoner2005@aol.com joeyoyo 01-26-2008, 11:21 PM Mike, My Toyota dealer replaced the computer in my 2002 camry v6 XLE, and they reprogrammed one set of the keys, and now my wife's key will not start the motor, I can hear the motor turns, but the car will not start. Do I also use the same set of instructions to reprogram my wife's black key? FOR 2002+ 1.Make sure all doors and windows are closed. 2.Insert master key into the ignition cylinder. 3.Cycle the ignition cylinder from ON to OFF 5 times. 4.Open and close the driver side door 6 times. 5.Remove the master key and insert the new duplicate key. 6.DO NOT TURN THE IGNITION CYLINDER ON 7.The new key will be registered after 60 seconds.The THEFT light on the dashboard will go out,indicating that programming has been completed. "some 2002 will work using the 1998+ programming." tdvnewf 02-02-2008, 08:13 PM Hello, just bought used 2005 toyota matrix xr, only have one master key ( has dot on side near black key ring). What do i do to get another one without going to dealer. Also i do not have the remote FOB, any help? pearle@ns.sympatico.ca gph 04-20-2008, 10:15 PM I just purchased a 2007 Camry LE. It only came with a Valet key. I purchased a 12BBY remote head key on ebay. How do I proceed? Can I program this myself, or do I need a dealer to hook it up to a computer? I've read conflicting info about this. I guess I need to create a new master key, although I don't really know what that means. Please help!! email to paul_huettner@yahoo.com. Thanks!! ranhepp 04-21-2008, 07:02 PM I have a 1999 Toyota Land Cruiser and was wondering if anyone has instrucitons on how to program a second master key. I have one master key already and have a blank master I would like to add as a backup. I get conflicting information from dealers and locksmiths as to whether I can program this key myself or if a dealer has to hook up a computer to do it. Any help would be appreciated. Thanks. desert-drifter 05-17-2008, 10:39 PM I have a 2000 model Landcruiser with 2 black keys and for some reason they both stopped working, the immobiliser light does not go out at all and car does not start, can someone send me the pdf instructions to program my keys back in or any help wolud be greatly appreciated as I now have no car unless I get towed in to Toyota and let them rip me off! HELP!!! Thankyou in Advance Leon leon396@gmail.com jarhead1371 06-07-2008, 01:58 PM Ok, Here's the situation.... I bought a 2000 Land Cruiser at Poway Toyota and only received one key for the car with a transponder in it. I didn't want to pay the $250 to get the second key from Toyota so I blew it off. I tried a couple of times to get a second key at the local True Value that has a key reader that works when you stick the key in the box and it reads the car code. Then the guy puts in another key (only $35 bucks) and transfers the code to that key. Well, that works except for the fact that he screwed up the cut on the key and they never ordered any other key for my car because they are bone heads.... Guess what happens next? I lost my set of keys (with the exception of a non-working valet key) in Chicago at a meeting so I'm basically screwed. So I go on the net and get absolutely no help or conflicting help for the next few weeks. Thank god I have another car to drive in the meantime. So here's what I did... I bought two transponder keys on Ebay for $80 each. I call the local Toyota dealer and he calls Corporate and because I don't have a master key, Corporate has to authorize the replacement of the ECM which costs anywhere between $1200 and $1750. They send it out to the dealer who really knows nothing about the replacement program and the day that I'm supposed to get the ECM replaced, they tell me that I have to pay for two of their keys at $250 each and the programming which is 2.5 hours of shop time in exchange for the new ECM. So that comes out to almost $800 bucks. So I go through the roof. Almost beat the guys a$$ who is telling me this and I tell him to go F himself. So what do I do? I tow my car off their lot and then I go on the internet and found a guy in Jefferson City, Missouri who tells me the exact location of the ECM (behind the glove box) and how easy it is to take out. It takes 5 minutes...... I overnight this thing along with one of the cut keys that I have (without a working transponder chip) and he gets it and sends it back to me three days later. Cost? $200 for the ECM to be reflashed and $23 for shipping it down there overnight with $2000 insurance. He can overnight it for about 60 bucks so I go next day for 45... I could have been driving that thing three weeks ago!!!! My two keys off Ebay - $160, Overnight shipping the ECM $23, Reflashing the ECM - $200, Shipping it back $45.... Grand Total - $428.... Savings by doing it this way over going to Crown Toyota in Decatur, IL? $382 So what should you do if you've lost your keys? Go to Google and search for Toyota Reflashing or Toyota ECM reprogramming and a handful of sights come up. I chose the one in the neighboring state which is the guy in Missouri. http://www.a-1mobilelockandkey.com/losttoyotaandlexuskeysreflashingservice.html Never, Ever, Ever, go to the dealer for lost keys, purchasing a key with a transponder chip or anything else along those lines. Take 5 minutes to pull the ECM out of the car, overnight it along with a valet key to a guy like the one above and he sends you a reflashed ECM along with a new key for it that will start the car. If you did what I did and purchased two OEM keys with new transponder chips inside, they will provide instructions on how to program the other two keys and that's the cheapest way to do it. If you only have one key for the vehicle right now and don't want to pay the dealers BS cost, go and have a non-working key made immediately for $6 for an emergency back up and then go on Ebay and type in the something like "Toyota Land Cruiser Key" and a bunch of keys will pop up. Buy one at a fraction of the dealers cost and that guy will send along the instructions (not really complicated) to program those keys. Anyone can do it with an assistant to read off the instructions. Good Luck and never give the dealers money needlesly. They make their living ripping people off. Oso skillzunlimited 06-24-2008, 07:30 PM would you be able to email it to me 2002 Toyota Sequoia: salvin.wallace@hocmc.org Thank you in advance kaibug 09-06-2008, 04:45 PM Hi. I've got a new blank key from my dealer. I also have the black original key to my Landcruiser 90, 2000. Hope someone can send me the pdf-file explaning how to program the new key. My email adress are: kaijonny@hotmail.com Some instructions at the internet says that the ignition should be switch on after inserting the new key while programming this. Other sites says the new key just should be inserted, but NOT to turn on the ignition afterwards, so I'm a little confused. Hope someone can help. Thanks!:wink: honey7pk 10-10-2008, 03:40 AM Dear Mysequoia03 and other members Originally Posted by MYSEQUOIA03 Mike, Like I said from my previous posted, 2001/2002 Transponder key have difference chip from 2003 and 2004. Make sure you have correct part number. I am willing to send you a PDF file from TOYOTA dealer manual that included everything you need to program your key. Please leave your email address Mysequoia03 Kindly send me the PDF file. My email address is friends.advertiser@gmail.com. Regards SanFas 10-13-2008, 01:53 PM I just bought a 2005 Toyota matrix. It came with one Master Key and Remote. Can anyone guide me on how to get a second master key and remote? Guess both will need programming instruction... You can email useful information to sf@elsmedia.com Thank you lib135 10-27-2008, 10:38 AM I am looking for instructions as well.2004 4Runner. aenehzodaee 12-12-2008, 08:32 PM Toyota mr2 spyder, lost master key. I ordered an ilco blank key for toyota. Need to program new key without original. jerry sosa 01-05-2009, 07:38 PM hello i bought a used 02 sequoia 3 years ago but ran into a problem ignition switch gave out and was forced to buy one "dealership" took an arm of wasnt told after taking the broken one of and putting the new one on i had to progam it in order to start called back and now asking for $100 dollars more to program the new keys can anyone help please. agarcia7434@yahoo.com deanbob 01-06-2009, 11:23 PM I 2 master keys and the valet key for my wife's 2009 Camry. I have ordered a blank for a spare. After get it cut, how do I program it? Could you send details to d.mounts@verizon.net ? Thanks in advance for your help. Automotive Network, Inc., Copyright ©2012
