01-17-2004, 06:14 PM
S-10 Blazer Squeaky Rear Window
My 1988 S-10 Blazer has a squeaky rear window/tail gate. I know this is a common problem in this model. I have tried everything I can think of, including: (1) putting a special silicon lubricant on all the weather stripping, (2) replacing the hatch window U-lock mechanism, and (3) replacing all the weather stripping. Each time the "fix" seems to work for awhile and then the squeaking returns. I am sure there is a simple solution. Someone please tell me! Thanks. Lowell
01-18-2004, 06:42 PM
Re: S-10 Blazer Squeaky Rear Window
does your tailgate have a spare tire on it? my blazer had one and it squeeked very badly and i thought for sure it was the glass, but not so....if you grease the part where the bar attaches, or rests, on the tailgate part the noise will stop. hope that helped
01-18-2004, 08:05 PM
My tailgate does not have a spare tire bracket on it. Thanks. Lowell
01-20-2004, 08:03 PM
oh....crappy, i was hoping i was going to solve that for you! lol, anyways i'm fresh out of ideas, sorry!
01-20-2004, 10:03 PM
Thanks for trying. Lowell
01-20-2004, 11:18 PM
Lowell....My Blazer was doing the same thing. I set the adjustment for the window lock mechanism (the lock that the u-latch goes into) in the tailgate as tight as possible and it seemed to solve the problem for me.
Hope this helps....
Dr
01-21-2004, 12:56 PM
A tab of grease on the u-hook where it contacts the latch. Also spray some oil or grease on the hinges at bottom of tailgate, these will make noise that can't be pinpointed sometimes.
01-24-2004, 06:10 PM
I had that same problem on one of my other s10 blazers I found out it was the bolts that hold the window in so I tightened it up shattering the window eliminating the problem sorry I didnt find a better solution
97 S10 truck
headers by jba
intake by volant
ignition by msd
fuel pump by venom
fuel injectors by vemon
computer by hypertech and myself
exhaust by flowtech and myself
maf work by myself
throttle body work by myself
and a bunch of little stuff
5 grand in parts for the engine total
and 6 sets of tires in the last 2 years
sorry about the over estimation earlier
01-24-2004, 09:29 PM
Hope this helps....
Dr
Dear Dr. Blazer,
I think I have isolated my problem and that I need to adjust the window lock mechanism (make it tighter). Do you have any advice for making this adjustment or is it intuitive, i.e., when I take off the paneling will the adjustment process be obvious?
Thanks,
Lowell
01-24-2004, 09:30 PM
Re: Re: S-10 Blazer Squeaky Rear Window
Thanks for the suggestions.
Lowell
01-26-2004, 10:22 PM
Originally Posted by Lowell
Dear Dr. Blazer,
Thanks,
Lowell
Lowell....The lock adjustment is fairly obvious after pulling the finish panel from the tailgate.There are 2 nuts on studs which face the left side of the gate.Just undo these and adjust the lock mechanism to where ever you like.This helped my squeeking problem. I also replaced the pins in the tailgate hinges as they were getting very worn and allowed the gate to move up and down as I drove.
Dr
01-27-2004, 12:50 PM
Re: Re: Re: S-10 Blazer Squeaky Rear Window
Dr
Dear Dr. Blazer,
Your instructions were clear and easy to follow. I adjusted the latch which makes for a tighter fit when the tailgate glass is closed and now the squeak is gone. I plan to replace the pins in the tailgate hinges also. Can one buy those separately at the parts dept of a Chevy dealer?
Thanks again for advice that actually worked!
Lowell M. Dicke
01-30-2004, 01:19 AM
Hey!..Thats great,Lowell. I'm glad it worked for you. As to the hinge pins,I'm not sure if they are available at the dealer. I just drilled out both hinge halves(body side and tailgate side) to 5/16" and then installed 5/16" x 5" long bolts with double nuts.Its working for me,but then,I'm kinda cheap!(LOL)
Dr
01-30-2004, 08:52 AM
Dr
Great idea! Thanks. I'll try it.
Lowell
