turning signals acting goofycreep13x 01-17-2004, 06:50 PM my turning signals won't work unless i pull the stick back until my brights are damn near on. otherwise the light will stay solid and unblinking. anyone have any ideas. they were that way when i bought the car, but it's grown worse. camodiak 01-18-2004, 08:37 AM mine does the same, only with the brake lights though, i've deterined it's the box inside of your steering colum that the stick is attached too? make sense? tim michelq 01-18-2004, 12:10 PM check and make sure all bulbs are ok. if bulbs ok then you have bad turn signal switch in steering calumn Metal_m_a_n 05-22-2004, 11:16 PM I have a 92' Eurosport and havn't had that prob, but my grandma has a 90' 2.5L and her blinkers did the exact same thing....I had to drive it one day and figured you had to pull them back......It bothered me so much that while I had the car I decide to fix it....I had to take the whole steering wheel off...Poped the horn button off...Took nut retainer off and had to use a 4 way lug wrench to break the nut loose...But be careful....when it finally broke loose one end of the wrench hit the visor and ripped it to shreds....Lol....But I got that all appart and theres just a bunch of copper contacts in there...I took the thing out and scrubed it with a wire brush and then rubbing alcohol and then put wd-40 on them to prevent it....Put it halfway backtogether just to check it, and it worked just fine.....To this day..about 2 years later it still works fine...You will need to get one of the pullers for the steering wheel or I just made my own out af a huge washer and some bolts that fit in the steering wheel....Have fun with it....Its a pain.....But its worth it to not have to fuss with the blinkers even for a few days....And I was forgiven for the tore up visor since I got it fixed. Euroguy026 05-23-2004, 03:29 AM i had this prob, but when i turned my blinker on it wounldnt blink just stay lit, its a Flasher Fuse is what the call it, its acctually at the Bottom of the Steering Colum, ripp the plastic outta the way and pull the old on out, i bought a replacment no more than 7 bucks, n that was for the higher brand lol, u need to get the old one out first and make sure the ends match up is all, i changed my singals were fixed afterwards, and Still nice and Good Automotive Network, Inc., Copyright ©2012
