B16A swap wiringdefman 01-15-2004, 10:19 PM I have a 94 civic cx, I have ordered an SiRII motor for it(complete swap). I think since my car has OBD1 wiring that it will plug in. but do i have to run any extra wires for Vtec, Knock sensor, exc....? Smokn91HB 01-16-2004, 08:37 AM if your car is non-vtec now yes you need to run, i think its like 4 wires for vtec.. im not sure about the conversion i think you will be ok.. but im not sure defman 01-17-2004, 08:38 PM does anyone know the specific location the wires go on the ecu, and where they go? Smokn91HB 01-18-2004, 01:09 PM the ecu should be on the passenger side under the carpet (in the front seat) somwhere around there and the wires go into connectors right on the side of the ecu. salbaje 01-19-2004, 01:38 AM which harness will you be using?? if using your cx harness you need to rewire to a 4 wire o2 sensor, add vtec wires,knock sensor wire. defman 01-23-2004, 09:25 AM I have to use the cx wiring harness because the jdm wiring harness is for a right side driver. Why do I have to have a four wire O2 sensor when i only have a one wire sensor now? Smokn91HB 01-23-2004, 12:26 PM thats just how they have it on the b series, you need to convert it or the ECU will probably throw a light about the o2 sensor if you keep it one wire.... Automotive Network, Inc., Copyright ©2012
