Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 01-15-2004, 08:52 PM   #1
JGTP94
JGTP94 Normal reputation
Send a message via AIM to JGTP94
91 jetta Hole in firewall?
Hey,
My friend has a 91 jetta sedan and we were installing a system in it and we cannot find a place to run the power wire to the battery. does anyone have any ideas on how we can do this or where we can run it??
Anything Helps! -Thanks-
Jason
JGTP94 is offline   Reply With Quote
Old 01-16-2004, 11:08 AM   #2
termitesgraffix
termitesgraffix's Avatar
termitesgraffix Normal reputation
Send a message via AIM to termitesgraffix
pull up the carpet under your pedals or on the driver side. look for an exsisting gromet with wires already coming in. pull it out and run the wire in with them. get a gromet the wire will fit in and drill a new hole(the size of the gromet), making sure there isn't anything on the other side to hit. pull the wire through the hole, slide the gromet on, pop it in the hole and done. replace carpet and good to go.i would do it just to the right of the fuze box, but not too close. do not put it in the way of the pedals or any moving parts. plan it out well.
termitesgraffix is offline   Reply With Quote
Old 01-27-2004, 03:20 AM   #3
rollovr6
rollovr6 Normal reputation
I installed a system in my jetta, and the other guy was right. I found a spot that is, if I remember correctly, pretty much directly behind your clutch pedal. I don't recall having to pull up the carpet though. It WAS filled by a black rubber grommet that didn't have any wires going through it. In fact, I don't think it even had a hole in it. Anyways, I just popped it out from inside the car into the engine compartment. If you open your hood and look down at the firewall on the drivers' side, way down behind the expansion tank and a bit to the left, you can see it fairly easily. This will give you a better idea of where it's located when you're all cramped under the steering column and fuse box (don't get stuck!) If you can, maybe pop it from the engine compartment into the car. That way you can punch a hole in it, run your wires through it and stick it back in place. Good luck
rollovr6 is offline   Reply With Quote
Old 01-27-2004, 08:49 AM   #4
termitesgraffix
***getting stuck*** taking the drivers seat out(be-it a pain) will make it more roomy to work there.
***carpet pull*** you would putt the carpet up if you want the wire to go through the floor, but that gromet you speak will work. I would buy a new gromet to fit with a split and hole in it. not punch a hole though the old gromet. that is sloppy. and not sealed.
Bookmarks
Google
Web AF
