Eclipse injectors in a CRX
kokujin
12-24-2001, 08:12 PM
On the homemade turbo homepage the guy uses 1g Eclipse injectors for his ZC engine. Will these be a direct fit or is there some sort of adapter kit that you will need?
pvang31019
12-25-2001, 12:51 AM
I don't really remember, but I think you need the injector o-ring seals. PLus, you'll need a good fuel computer to turn them down.
91zc
12-27-2001, 12:35 AM
You might want to replace the seals like pvang31019. The injectors are 450cc and they are peak and hold so you won't need to change any wiring except for the afc or v-afc that you will probably use to lean out the injectors. They will be spraying a ton of fuel into your combustion chambers.:)
marked001
01-03-2002, 09:23 AM
you need the plugs off of the eclipse harness as well....you'll need to cut off the plugs on your harness and splice these in...
