Sound System Problem
Danijh1
01-14-2004, 07:34 PM
Alright..... i have all new door and 6x9 speakers in my car now....
I also have 2 12" subs, 500 watts each sub and a 1000 watt amp.
i dunnno whats the problem is ....when i turn on my car and then turn my music up... there is this eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeee niose that always comes up.... i pause the music and the eeeeeeeeeeeeeeeeee is still there.... the funny part is this.... when i start driving and hit the gas pedal.... the noise gets louder and louder and when i let go of the gas pedal the noise gets lower....
i dunnno if i need to get some shielded audio RCA Cables...from my Cd player to my Amp....or...........WHAT.....
When my car is OFF the music playes no problems.....
dj_xtreme_97_neon
01-15-2004, 12:22 AM
there is a problem with your electrical system, such as bad coil, or your RCA cables are to close to your "HOT" wire. Re-locate your RCA cables running to your amp and if that does not solve the problem, try numerous electrical changes... this is only what I have heard... Good Luck.
dnkygirl
01-18-2004, 11:24 AM
The whining sound could be that your amps are not grounded properly. Check your grounds.
demi
Danijh1
01-19-2004, 08:52 PM
If the ground is not right......
The thickness of the ground wire matters?
1000 watt amp...
and where is the best place to put a ground cbale from an amp...?
