Throttle body Cleaningpoppy_morenito 04-19-2001, 02:53 PM My car is doing lot of hesitating after driving fast and then coming to a stop. I just got a new motor in it ( new used one) It was running great for a week ( It really pulled hard from first despite being an automatic )then I noticed that ther was water leaking out of the bottom. I took it to local shop and they fixed the leak ( I saw it it was way under the motor ) Now, the car does not pull hard anymore and hesitates and even cuts off. I think maybe they dirtied up the throttle body or something. I saw the directions to clean the throttle body on SE-R net but I am afraid to disconect the wrong thing and how to keep it open ( they suggest a broom stick ??/) Can anyone help me with this ??? Maybe I need more pictures ..hopefull my haines manual will be here soon ... kris 04-19-2001, 10:30 PM I would sugest taking the throttle body off completly. I dont like th idea of spraying all that gunk into my motor. If you need some pics, i can maybe try to take some tomorrow (friday) for you. :alien2: Kenny-G 04-19-2001, 11:36 PM Couple of checks you can do... Check ignition timing, go se-r net and you can find out how. Have a friend step on the gas for you, and you go see how is the exhaust flow from the tail pipe. Or have you local Midas store check the CAT. ( Just kinda sounds like ignition timing way retarded or a plugged CAT ) You got new plugs and wires and stuffs like that when you got your motor put on? poppy_morenito 04-20-2001, 10:49 AM Mt timing is way advanced like to 17 degrees and no I did not get new plugs. Untill I got that leak and tok it to shop to fix the leak the new motor ran like a monster... snorting fire !!! ( almost ).. The idle was always at like 800- 900, Now it drop when ever I come to a stop to like 400-500 or just off. I had the care throttle boddy cleaned yesterday. The car runs really smooth when it is going but the idle is still dropping. Think new plugs and wires will help guys ? Someone on Yahoo suggested the TPS sensor ? Help It is embarrasiing when I mini race from one light to another ..smoke the car then cut off ..lol .. Automotive Network, Inc., Copyright ©2012
