need help [ again ] please
turbo type-r
01-14-2004, 03:42 PM
my tmaxx wont start the gear spin and i hear a sound from the exhaust but it wont start does anyone know what to do
Asmenoth
01-15-2004, 02:29 AM
Well, you could check a few things...check the fuel lines for cracks and such. Just take them off, plug one end and blow into the other and listen for leaks. Or you could put the fuel line into a cup of water, with the open end and the plugged end sticking out and blow...if there is a leak, then you should see air bubbles. If this is the case, go to your local hobby shop and buy more fuel tubing.
You should also check your glow plug. If you have had the t-maxx for a while and it is the same plug that came with the truck...change it. It is suggested that you should change the plug after breaking in the engine.
If the plug looks discolored, if the filiment looks burnt or broke, etc..change it. If it looks fine and you have a glow plug ignighter, put the plug into the glow plug ignighter and see if it "lights" up. If it doesn't, or looks weak and/or dim, replace it.
If that doesn't work, try fresh fuel. Nitro fuel should last quite a while if stored properly...ie in a closet away from moisture and changing tempratures.
And if after all that, you still have the same problem...check out www.rccaraction.com and look on their forums for an answer. If you can't find one there...ask at your local hobby shop, they should more than willing to help you out.
:biggrin:
turbo type-r
01-15-2004, 11:26 AM
im such an idiot it wont start cuz the gas tank isnt fully closed . reason why is i put the tie strap on the fuel cover like it says on the dvd and whenever i pop it back in it doesnt go all the way . !!!!!!!WOW !!!!!!!!!!
Asmenoth
01-15-2004, 05:34 PM
HAHA! Well at least it was a simple, and cheap, fix.
:biggrin:
turbo type-r
01-17-2004, 11:46 AM
[QUOTE=Asmenoth]HAHA! Well at least it was a simple, and cheap, fix.
thank god for that
