Whistle when cold and low RPM
Google
Web AF
zimaad
01-14-2004, 02:22 PM
When I start my car when it is slightly cold (i.e. today about 30 deg...car is garaged) my 98 has what sounds to be a high pitch whistle. When I start to throttle, the pitch gets higher until it goes away at still fairly low RPM (under 2k). Once I drive the car for about 20 minutes it goes away. I popped the hood at start up and it was hard to pinpoint, but sounded like the AC pulley area..possible bearing???vacuum leak?? Anyone have any ideas here?
Thanks!
Randy1
01-15-2004, 07:40 AM
Try spaying some silicone on the serpentine belt when you start it and see if the noise
goes away. I had the same problem and that instantly stopped my sqealing noise.
jjdewd
01-15-2004, 06:52 PM
I have a noisey AC pulley bearing and spraying the belt does not help. I'm praying for an early spring lol so I can replace it
zimaad
01-15-2004, 11:02 PM
I've already replaced the serpentine belt. This doesn't sound like a squeal. It is higher pitched and sounds more like a whistle (like air moving).
bustedratchet
01-18-2004, 11:33 AM
I can't think of any vacuum near the A/C pulley area. Turn the defrost on to engage the A/C clutch and see if the noise goes away.
Google
Web AF
