Re: Extreme Play in Steering
Loose steering is not normal for this jeep, mine drives very tight but does wander a little in cross winds due to its hight.
there are only a few things that will make a jeep steering feel loose.
1 is the track bar that holds the front end straght with the frame and will affect the steering a lot.
2 Loose steering shaft joints or steering box.
3 Bad tie rod ends or tires out of round
4 worn out shocks or bad alignment.
5 loose body to axles componites including ones on the rear axle.
Hope some of this may help locate the prolbem.
