suggestions for ls interals build upDoMeStiC_kila 01-13-2004, 01:13 AM ok, i have decided that i want a turbo ls engine and want to run about 13-14psi on the ls motor. I also want the engine to with stand the boost pressure ill be putting on it. I have known that good internals are good insurance so what types of parts am i going to need to take the boost load? and also what types of companies are the "best of the best". I know crower makes good stuff but thats it. thanks in advance. tibby01 01-13-2004, 01:42 AM rods, pistons, but the crank should be fine. check this out. http://www.groupbuycenter.com/buy.aspx?id=11924 pauter, wiseco, arias, and crower make some good things. whtteg 01-13-2004, 06:27 PM I would also put a block gaurd in there as well for extra saftey. Forged pistons arpound 9.0 or 8.5 somewhere around that c/r and new rods like tibby01 said. Also get hondata you will be thankful if you do, trust me. DoMeStiC_kila 01-13-2004, 07:57 PM i think i have decided to go with some crower rods, and some new arias pistons w/ 8.8 compression ratio. i have looked at arias's website and 8.8 is the lowest c/r they make. those should work perfect right? i think im pretty sure those will work but i want to be sure. thanks in advance. tibby01 01-13-2004, 11:38 PM its all about tuning everything. it will not be a swap in and go type thing. when messing with internals, your going to need some tuning time on a dyno. DoMeStiC_kila 01-14-2004, 05:26 PM yeah, i have a friend that can hook me up on the tuning and dyno runs. so the tuning and stuff is no problem. i just want to be sure that i have all my parts together when i get my engine Automotive Network, Inc., Copyright ©2012
