1994 Ford Explorer Keyless Entrytecrules 01-12-2004, 09:19 PM How do you program the remote for a 1994 Ford Explorer. I know that you have to do something with the box in the left rear 1/4 panel but what exactly. thanks kekul 01-15-2004, 08:47 AM If you are talking about the keyless entry via the key fob. Turn the key from off to accessory position about 5 times in rapid succession (less than 10 seconds total time and end in accessory position) You will hear the locks cycle, then hit the lock and unlock buttons on the key fob. It will set the remote. If you have more than one remote, make sure to do them at the same time. For the keyless door entry (number combination) check the back panel where the jack is stored for the factory preset code. tecrules 01-15-2004, 09:59 AM Hi thanks for replying but i have a 1994 Explorer and that is different than the 1995 and up explorers. I have to jump some wires in the back by the jack and then my explorer will enter programing mode. i am not even sure if i have keyless entry for my vehicle. there is a black box right in front of the jack so i am hoping that is for the keyless entry but i do not know for sure. i can not find any wires on there to jump. thanks for the help and if you know anything about that black box back there then that would be greatly appreciated. thanks again. Mike cerealkiller696920 03-16-2004, 12:40 PM ok i have a 94 and this is how I did it I just bought a new remote and it works great....you know where the box is in front of the jack that is you alarm box take a small paper clip and bend it in a U for a jumper on the box are 3 connectors the lower of the 3 is the one you want. have all remotes for the truck in your hand turn the ignition to ACC and leave it that way unlock all doors. take the paper clip and jump the top left and lower left wires on the lower black connector the locks should cycle ( close and open this is program mode leave the paper clip in take your first remote and hit lock the doors lock take your second and do the same. Both remotes are now programmed turn the key off and remove now takee the paper clip out you are all set. tecrules 03-21-2004, 02:07 PM Hey, this remote thing is really making me mad. i followed your directions to the t, i think and nothing happened. is acc towards you or away from you. that is one thing that i was not 100 percent on. can i email you two photos of the box in question and maybe you can pinpoint which wires to jump. thanks a lot for all your help Mike cerealkiller696920 03-31-2004, 08:33 PM [QUOTE=tecrules]Hey, this remote thing is really making me mad. i followed your directions to the t, i think and nothing happened. is acc towards you or away from you. that is one thing that i was not 100 percent on. can i email you two photos of the box in question and maybe you can pinpoint which wires to jump. thanks a lot for all your help Cerealkiller-----ok the acc position is the position the key is in when the vehicle is running but do not start the truck, turn the key forward just before you engage the starter. Have all the doors unlocked( by using the power controls. now have all remotes for the vehicle in hand. remove the jack cover. on the alarm unit you will have 3 harness connections the one you want is the lower. with the key in the acc position use a metal paperclip bent in a U to jump they top left wire (gray with a yellow stripe) and the bottom left wire ( white ) the locks will cycle closed then open to signify programming mode. press the lock button one the remote. then press lock on your second remote both are now programmed. Turn the key to off and remove, then remove your paper clip jumper replace cover and thats it. Any thing else contact me if I can help at cerealkiller69692002@yahoo.com j_platinumplus 06-30-2004, 06:59 PM A HUGE thanks to cerealkiller!! I would have NEVER figured this out it it weren't for your instructions. I have a 1994 and a 2002 Explorer and I have new keyless entry for both. The 2002 was a piece of cake but the 1994 was a pain. Thanks again! johng1027 11-11-2006, 11:56 AM A HUGE thanks to cerealkiller!! I would have NEVER figured this out it it weren't for your instructions. I have a 1994 and a 2002 Explorer and I have new keyless entry for both. The 2002 was a piece of cake but the 1994 was a pain. Thanks again!there is also black 2 pin plug attatched above the jack area were you can do this paper clip jumper.wire colors were white/ yellow and a grey yellow. guido0136 12-28-2007, 09:23 AM okay - here is a pic of my 1994 access area. I can not find the wires. I'm assuming mine does not have the option but I'd like to make sure. Thank you... http://i258.photobucket.com/albums/hh247/guido0136/PC280174.jpg way2old 12-28-2007, 06:57 PM Look at the date of the post. Original is about 3 years old, you responded toa post that is over a year old. Please start a new post. This is digging up a dead post. I am going to lock the topic. Read the forum rules. There is a time limit on dead posts. Thanks for understanding. Automotive Network, Inc., Copyright ©2012
