'94 Concord
roguefive
01-12-2004, 06:14 PM
Gas gauge does not work. Checked fuse. Is there something else other than the sending unit in the tank? Also leaks oil. I'm figuring front seal. Does this model have a pcv valve? If so,where is it located. I'm trying to help a friend in need.
mike_b
09-01-2005, 10:06 PM
Ok.. the gas gauge does not work because of the sending unit on the gas pump. When and if u replace the gas pump it will work... because the pump comes with the entire assembly (300$ CND). The pcv valve is located right in back of the engine next to the air intake module. (look for the hose that enters the engine in the rear (on top).
Good luck (had same problems with mine.) The oil still leaks though. its most probably a set of seals. Try using thicker oil.
