Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tercel
Old 01-12-2004, 12:30 PM   #1
gator2764
gator2764 Normal reputation
Timing belt replacement
Has anyone out there relaced the timing belt by themselves on a 92 tercel? I bought one used with 145K and figure even if it was replaced(like he said it was) I better go ahead and do it. I have never replaced a timing belt but have rebuilt a few engines and want to know if it takes a rocket scientist to do this. Thanks.
gator2764 is offline   Reply With Quote
Old 01-26-2004, 12:36 PM   #2
rxbandits
rxbandits Normal reputation
Re: Timing belt replacement
No, its not to difficult the hardest part is actually setting the timing. You need to loosen the alternator, and remove the accessory belt, then remove timing cover. The crank pulley might take some work to get off you might need a breaker bar. then remove timing belt tensioner. Then all you have to do is set timing and put it back together, cant remeber exact procedure for setting timing. I will try and post again with procedure.
P.S. I did this on my 81 tercel hope its not to much different on a 92.
rxbandits is offline   Reply With Quote
Old 01-26-2004, 01:07 PM   #3
gator2764
Thanks for the reply. I was beginning to wonder if any has had to do this. My 92 is just a commuter car with no extras on it. Just A/C. If you can think of any more info please post it.
Old 01-26-2005, 08:43 AM   #4
ztakis
ztakis Normal reputation
timing belt replacement
Just fyi alldata uses a 1995 tercel as a sample to get you to subscribe -- this would be similar for the basics of removal. AND don't pry grears off, use a gear puller there are cheap compared to damage that can be done.
Hope this helps.
ztakis is offline   Reply With Quote
Old 01-28-2005, 12:17 PM   #5
gator2764
Thanks, I will look at alldata. Passenger CV is starting to make noise now. I might as well relace everything at once.
Old 02-15-2005, 03:28 PM   #6
rhynes
rhynes Normal reputation
If the 92 engine is anything like the 90, be very careful with the crank pulley. Took me forever to get it off and I wound up cracking the pully around the edges.
After the crankshaft pully, the timing belt is easy. You may have to drop the engine on the passenger side to get the CS pulley off tho.
Good luck
rhynes is offline   Reply With Quote
Bookmarks
Google
Web AF
