On my 95 explorer, the "plastic" headlights and corner lights has become "cloudy", kind of a yellow film.
Is there a product out there that fixes that?
Thanks
You can spend your life trying to fix this. I just bought Taiwan replacements. Brand was Eagle Eyes for about $38 and they were good quality compared to other replacement parts. Even came with new lamps. Makes a great change in appearance. Shop around for a local supplier.
Thanks
I had a 96 lincoln continental with the same problem and I purchased a tube of Maguiar Blast-X and it worked like a charm the lenses cleared up immediately. you can find the product in any automotive store
good luck
Yes there is a fix.....You can wet sand them with 1000 grit paper then 1200 grit and then spray some clear on them...Just krylon in a can will work..Used to do this on Mustang GT headlights. They look like new when done right.
Hope this helps.
