Re: engine stalls after warm start
Have you tried testing the Intake Air temp sensor? Or the Idle Air Control motor? Check those two. I checked the IAC by removing it and plugging it in and having someone else turn on the ignition. My other method was to remove it, compress it, and then plug it back ing, but that's not necessarily recommended. For the IAT, Just hook up an ohmmeter to it and change the temp around it by bringing it inside and see if the resistance changes. Hope that helps
"If you have tried to do something and failed, you are vastly better off than if you had tried to do nothing and succeded"-----(someone famous)-----
