transmission questionstephenC 01-11-2004, 12:01 PM I just got a 96 explorer for next to no $. Even if I have to replace the tranny, it's a good deal. There again, don't want to if I don't need to. The problem is when I'm doing 70 and apply gas, the RPM's increase, then begin to decrease again, without my letting off of the gas. I have no basis of comparison for this car, as every car I've owned has been pre 1957, or a standard shift. There are no other malfunctions, no lights, nothing. Any thoughts? speedindevil 01-12-2004, 12:08 PM Could be a few things, fuel filter, pressure regulator, maybe even MAF, does it do it any other time at other speeds? Opera House 01-12-2004, 02:51 PM If the change is about 300 rpm it is probably the torque converter clutch locking and unlocking. I would check the throttle position sensor. These get intermitant in the range they are usually at. Trans could be thinking you are trying to accelerate. stephenC 01-12-2004, 04:30 PM Where is a throttle position sensor, and how is it checked? Thanks! Opera House 01-13-2004, 09:46 AM The TPS is located on the engine under the throttle body cover. A black device with three wires. A voltmeter is connecte to the center wire and one of the others. The throttle is then moved and you look for a smooth change in voltage. Automotive Network, Inc., Copyright ©2012
