95 neon has problems
amysinsanity
01-11-2004, 01:19 AM
I have a 95 neon. Its been nothing but problems ever since i bought it. I go through head gaskets and thermostats like mad. The car was the last thing my father-in-law bought before he died. getting rid of it is not an option. Any how now its getting sluggish when I step on the gas. It has several other problems too. I got jacked by the dealer when I took it in there, Im frustrated and looking for common problems in the coolant and fuel systems. I called the manu. and they told me to buy a new car with a warrenty if I want help from them. Any suggestions???????????
neilmac78
01-11-2004, 01:15 PM
try to change the spark plugs and plug wires , see if you air filter is good , or try changing the fuel filter but save the fuel filter for last because i think the filter is in the tank its self. get some fuel cleaner , maybe your injectors are dirty. you can also try using the high prices moble gas for a few weeks if you are using regular gas. moble has very good cleaning gas.
carguyinok
01-11-2004, 01:25 PM
The radiator cap on Neon's will cause big time cooling headaches. Change that out before anything else. The headgaskets are another Neon downfall. You may want to look around and ask on neons.org. I know there are a few people there that have had dodge pay part or all of the cost on a headgaskets. :2cents:
Scatch!
01-13-2004, 11:36 PM
But the headgasket should NOT be a problem any more if it was replaced PROPERLY. If you have had more than one HG installed, get a new mechanic because you're getting screwed.
On the sluggish performance, plugs and wires usually fix the problem. You may also look at air filter O2 sensors (upstream usually), Throttle position sensor, crank sensor, in that order.
PrplNoodles
01-14-2004, 12:05 AM
Have you tried to cycle the key (on-off-on-off-on-off-on) to get any codes?
amysinsanity
01-14-2004, 12:43 PM
The head gasket was done by a very good ASE certified mechanic. I know it was done right. I watched every step of the way. We're are now going through the codes one by one and checking everything, but its only giving me 2 digit codes with the key. I'm going to try replacing the 02 sensors may as well do both while im we're there. I'm thinking that this car was 1. stolen at some point. 2. I know it wasn't properly taken care of. ( I love my sister and everything but she doesn't know how to take care of cars, does't understand that if you don't take care of them they dont last) 3. wrecked at some point I need to get a carfacts on it. Thank you all for your suggestions and im checking anything so, everything helps.
Scatch!
01-14-2004, 09:41 PM
That would be the first time I've ever heard of a blown headgasket on the new-design headgasket. ASE certs or not, something wasn't done properly. Unless of course the engine was overheated at some point. Then all bets are off.
Oh, two-digit codes will be all you get on a G1 Neon. http://www.neons.org/faq/FAQ_ET.html#OBD
Before you replace the O2 sensors, have them checked, because they are not cheap, and they are very easy to check.
mikeymike25
05-04-2010, 11:02 PM
I have to0o0 say i'v had my far share of cars an my neon blows them out by far...they really thought about someone workin on the car instead of buring everything thats for sure...wat car can u change a fuel pump in like 10 minutes cuz i did i mean i'v done everything their is to0o0 do0o0 to my neon besides just the brakes...
mikeymike25
05-04-2010, 11:16 PM
been their done that lol...an the fuel pump is right beside the feul tank under the car an ur cars sluggish sounds to me like the feul pumps gettin near its do date an i had the same problem but my car did start back up it just went out on my..i went to0o0 the nearest pick it pull it junk yard seen an neon with 40,000 mile an looked under at the feul pump an it was bright white so0o i pulled it payed 35 dollars talk about a steal an put the feul pump in in 20 minutes just a screw driver an hammer an pulled the two lines from the fuel filter off nocked the ring off that holds the fuel pump in dran the gas pulled it out put the other one in at a blink of an eye an got a new fuel filter for 20 dollars an thats just one 10 mil meter bolt an worked like new....an the coolant just had a problem with that 2 days ago the therasate didnt work an i just got one a year ago they dont last long thats the simple fix an on the fuel line thats on the top of ur engine that the fuel injectors hook up to0o theirs a nossel on the metal line it works just like a tire nossel if u press on it wen ur cars runin an it comes out like crazy that means ur fuel pump is not to blame
mikeymike25
05-04-2010, 11:18 PM
so0o how u check a O2 sensor
