fuel pump wont prime motor after swap help!
dropped93gsr
01-10-2004, 07:23 PM
ok i have a 93 integra gsr chassis with a 90 ls motor converted to obd 1 runinng a pr4 manual ecu, imusing the automatic wiring harness, however leaving the auto connectors alone,iwas told this works as long as ihave a manual ecu, BUT heres the problem, after the swap, when i turn my key, the fuel pump doesnt work, the fuel relay was tested, and works, when we bypass the relay, the pump works, could my ecu be bad ? i need to get this running thanks!
