Washer not workingvickybri 01-09-2004, 11:21 PM Hi: My 2000 Hyundai Elantra has only 28,000 kms on the odometer. Nearly new still. And yet my wiper/washer motor is not working. There is no sound, nothing. The wipers work, just no spray. I thought it might be a fuse that is blown. Has anyone else had this problem? And what did you do to fix it? Thanks in advance. tibby01 01-09-2004, 11:42 PM it should still be under warranty...take it to the dealer. shouldnt cost a thing to fix. im guessing a wire came loose. vickybri 01-09-2004, 11:48 PM it should still be under warranty...take it to the dealer. shouldnt cost a thing to fix. im guessing a wire came loose. You're right. It should still be under warranty. I'll also look into the loose wire response. It's possible. I checked my fuses and there is no specific fuse that only operates the washer motor. Since everything else electrical works it can't be the fuse. Fco 02-04-2004, 12:12 PM I have the same problem. The solution is to change the washer pump located in bottom of the washer tank. The price is around 20 USD. Automotive Network, Inc., Copyright ©2012
