Any help with my 93 Loyale?porksoda 01-09-2004, 03:33 PM My car died in the middle of the street. :mad: I suspected the fuel pump, but it tested fine. I've noticed that the distributior rotor isn't spinning when I try to start, and I suspect that may be my problem. The rotor isn't broken, the whole "shaft" just isn't spinning. I don't know a lot about this stuff, so any wisdom you could pass along would be helpful. roccovw 01-25-2004, 07:09 PM My car died in the middle of the street. :mad: I suspected the fuel pump, but it tested fine. I've noticed that the distributior rotor isn't spinning when I try to start, and I suspect that may be my problem. The rotor isn't broken, the whole "shaft" just isn't spinning. I don't know a lot about this stuff, so any wisdom you could pass along would be helpful. Your timing belt is broken. Calebz 03-31-2004, 12:41 AM More specifically, your dirvers side timing belt is broken Automotive Network, Inc., Copyright ©2012
