removal of steering column?barg80 01-08-2004, 09:38 PM I'm trying to run a new wire for my horn. I need to get this wire to the steering wheel, but i can't figure out how to remove the column to run the wire. Do you need special GM tools? and does anyone have a diagram or link to one, for removal of the column? modification_inc 01-09-2004, 06:50 PM You Need To Remove The Steering Wheel With A Puller. After You Get That Out Of Th Way It Shouldnt Be That Hard To Do. What Year Is It? 97blazerct 01-10-2004, 12:44 PM You Need To Remove The Steering Wheel With A Puller. After You Get That Out Of Th Way It Shouldnt Be That Hard To Do. What Year Is It? when i replaced my horn i just neded to hook the wiring, under the hood, from the old horn to the new.. i didnt even take the old one out.. mounted the new one somewhere else.. oh and to remove a steering colum.. rear end saturn.. worked for me, ripped right out of the axle.. lol in my old truck barg80 01-12-2004, 12:02 PM it is a 1991 s10 blazer.. i found out that you need a lock plate remover.. so im going to get one.. its only like $15, or you can borrow one from auto zone. and unfortunatly 97blazerct my current wire is bad, so i need to run a new one to the horn. Automotive Network, Inc., Copyright ©2012
