Skunk2 Coilovers
Google
Web AF
7eK
01-08-2004, 04:32 AM
Getting my baby back on the road after a long ass year!! I have a lot of work to do on my 93 ex to get her up to par again but the first thing I have to take care of is suspension. I'm currently riding on Skunk2 coilovers and stock shocks/struts (bought it that way, my first project car so I'm learning as I go). My ? is, what would be a good shock/strut setup to work with these springs? I don't have a ton of cash to blow but I want it done right. I've looked a little into KYB AGX's, but like I said, I'm learning as I go. Any opinions on this one? Your help is greatly appreciated!
:7eK:
SilverY2KCivic
01-08-2004, 12:45 PM
Koni Yellow shocks. Because of the twice as high as other coilover sleeve springs rates, I wouldn't put any other shock with Skunk2's. Simply no other shock would last a length of time on them. They are about a 500lbs/ft front and 400lbs./ft rear rating of the springs, which is quite a high spring rate number just for the street. Skunk2's are all business (road race spec) and not very suitable for the street for general comfort. :2cents:
Doubletap
01-08-2004, 12:46 PM
Welcome to AF. One of the great things about this site (and every other one I have ever seen) is that you can search through old posts using the search forum. That way you get answers instantly. Try it its fun.
DoubleTap
Doubletap
01-08-2004, 12:47 PM
Hell if you just scroll down a little bit you will see 3-4 of this exact same question with slight semantic differences. jeez
DoubleTap
7eK
01-08-2004, 01:12 PM
Thanks for the info Silver, it's appreciated. I'll check out the prices on some yellows.
And Doubletap, another great thing about this place is I can come right back and tell you I used the search feature and read for about 2 hours this morning before I posted. I was looking for a little more info on my specific application, and hopefully someone with the some experience with the same product.
Well, all sarcasm aside, this is a great forum and thanks to all who provide such a great service to us noobs.
:7eK:
BullShifter
01-08-2004, 08:10 PM
If you order KYB AGX's & read the paper work before installing, you'll see that the warranty is void when used with aftermarket adjustable spring seat & collars. Go with Koni Yellow's.
How much of a drop do you plan on?
SilverY2KCivic
01-08-2004, 09:48 PM
Very good point there. *makes note to include that in suspension FAQ* ;)
7ek No problem. Not trying to sway you away from the Skunk2's, just trying to sway you into getting the correct shocks to match them with. :cool: You won't be dissapointed with the little extra $$$ the Konis cost. Unlike other shocks out there (Tokico Illuminas, and KYB AGX) Koni Yellows can be revalved (from what I hear) to compensate for stiffer spring rates, or for a more user customizable ride handling performance and feel.
7eK
01-09-2004, 08:43 AM
I think I will go with the yellows. As far as the drop, god it's been so long since I have touched that car but I'm pretty sure I'm around 2" all around. Give or take. Im pretty happy with the Skunks, just not with the combination. I don't think I have heard a single comment referring to yellows in a bad light. Now it's just time to start saving $$$!! :uhoh:
Thanks for the help guys. Anything else I should upgrade/replace while I'm down there?
SilverY2KCivic
01-10-2004, 12:06 AM
Yes, swaybar(s) if you haven't yet already, particularly the rear one. Get something that's at least 14mm in diameter. And if it's bigger than say 19mm, you'll want some sort of subframe reinforcement to go along with it.
I'm guessing by your username you drive a 6th gen hatchback? :confused:
7eK
01-10-2004, 07:18 AM
I have an ITR swaybar in the front but nothing in the back, that's definitely something that will have to be remedied!
As far as my username is concerned, nah, I drive a 5th gen ex coupe (93). It's actually derived from an old nickname/alias TeK. Everywhere I go it's already in use so I just use 7eK, I didn't realize what else it could mean until I already registered for the board. Sorry about that.
BullShifter
01-10-2004, 01:28 PM
Get rid of the front sway, your making handling worse than it already is by increasing understeer. FWD, by the law of physics, has understeer as a natural characteristic. One of the main goals of upgraded suspension is to increase oversteer(larger rear sway) to make the car "neutral" or a slight bit of oversteer.
Sway bar tips/advice - http://www.suspension.com/stam-bar.htm
SilverY2KCivic
01-10-2004, 02:55 PM
Easy fix, sell that ITR front bar, and get a stock 5th gen EX front sway, and get an ITR rear sway for your ride. www.beaksproducts.com sells an EG Civic ITR rear swaybar upgrade/add-in kit for your car. It'll GREATLY improve your handling as I have an ITR rear swaybar on my '00 Civic coupe, and no front sway at all the speak of, and my handling is so nicely balanced.
Google
Web AF
