Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 04-18-2001, 04:15 PM   #1
Innate
Innate
Send a message via ICQ to Innate
Question
I'm getting my Impreza 2.5rs in next week and I was wondering what is the trick in spinning doughnuts in a AWD car? Specifically a 2.5rs
Innate is offline   Reply With Quote
Old 04-18-2001, 04:45 PM   #2
Heep
Heep's Avatar
Heep Normal reputation
Send a message via AIM to Heep Send a message via MSN to Heep
You can only spin if your rear tires lose traction while the fronts have traction...if the car is powerful enough, if can spin the rear tires. However, depending on torque split, it will more likey spin the fronts first because of rear weight transfer, causing understeer. Probly the best ways to spin an AWD are to go quite fast, slam on the brakes hard (without ABS), enough to lock the back tires (which have relatively no weight on them) but not the fronts. Then cut the wheel either way. The fronts have traction, the backs don't. Either that, or get going in fast donuts...then yank up on the handbrake. This will lock the back tires, but the front traction and momentum will spin the back around...in theory anyway. Try it, but be careful and have fun.
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Heep is offline   Reply With Quote
Old 04-18-2001, 05:19 PM   #3
enzo@af
Old Mod
enzo@af's Avatar
enzo@af Normal reputation
Send a message via ICQ to enzo@af Send a message via AIM to enzo@af
Yeah, E-brakes are fun
I've said it before, I'll say it again. "Nobody does rip and snort like Ferrari"
enzo@af is offline   Reply With Quote
Old 04-18-2001, 06:31 PM   #4
Heep
Heep's Avatar
Oh yeah, they're great.
Mark Brown
Old 04-18-2001, 11:19 PM   #5
flylwsi
flylwsi Normal reputation
Send a message via AIM to flylwsi
technically, that car should be able to break out in a tight turn, if you floor it halfway thru...
the e brake technique is more complicated w/ awd though, as you have to put the clutch in so as not to destroy any driveline pieces... that is part of how a rally car can crank those tight corners...
if you read the superstreet article on drifting, it explains the concept...
that should be easier in a wrx though... power good
flylwsi is offline   Reply With Quote
Old 04-19-2001, 02:26 AM   #6
unite@af
Old Mod
unite@af's Avatar
unite@af Normal reputation
Send a message via ICQ to unite@af
come on guys
If you want to through a 180 or 360 put in the clutch or put it in neutral. Im suprised you guys havent thought of this yet. It does work. I have 3 subarus.
SUBARU" is a Japanese word meaning "unite," as well as a term identifying a cluster of six stars which the Greeks called the Pleiades
unite@af is offline   Reply With Quote
Bookmarks
Google
Web AF
