1991 accord revs up and down in nuetralroland1737 01-05-2004, 10:25 PM i replaced the throttle body but that didnt fix it any ideas? strodda 01-05-2004, 11:38 PM try disconnecting the tps. could be a loose connection, since its not totally off if will mess up the idle but will not throw any codes. 20HondAccord02 01-06-2004, 05:34 PM Does it only surge when it is cold starting or does it always do it? SenseiAccord 01-07-2004, 05:32 AM could be dirty injectors. Most of the time that is the problem. Hm... u said only in neutral this happens so i dont think it is dirty injectors. i am assuming ur car is auto and it doesnt happen in park or in gear at a stop. unless u have 5 spd and this happens in neutral and in gear but pushing the clutch down then my guess is the injectors. pressoranks 01-07-2004, 02:52 PM Last time I saw an Accord with that problem (a 92 4 dr), it was caused by a weak PCV valve hose,. The hose would collapse under the vacuum pressure and close off causing the engine to rev up and down at idle. mgcatthew 01-09-2004, 08:22 PM i agree with the pcv valve, happened with my 92 accord accordztech 01-12-2004, 03:57 AM it can easilly be your fast idle valve that you have to adjust. i encounterd many people with this problem. PM me for directions. but it can be PCV.....if there is a leak in it....if its clogged it wont do a tthing. NewOrleansGuy 01-22-2004, 04:54 PM Adjust fast idle valve? Replace it, it will solve the problem. Automotive Network, Inc., Copyright ©2012
