01-05-2004, 04:01 PM
AF - Advisor
"Skinnies"
I am going to be buying "skinnies" for the front of Hyde for the upcoming season. I have never driven with 4" wide front tires before .... and coming from the land of lateral gri and autocross, I must confess that 4" wide rims/tires seem inherently dangerous.
Is there anything I need to be worried about?
... anything I should know?
I realize I do not want to demostrate the wonderful handling ability of the MR2 while these are fitted on the car ... I am speaking specifically about going down the track.
What should I expect?
01-06-2004, 05:38 PM
Re: "Skinnies"
less rolling resistance nd lower e.t's!
seriously though, there is less control, but in drag, not too bad.
take a practice pass or two to get the feel.
Mustangs are nice, but I'd rather have one of these...
01-07-2004, 08:45 AM
Back from the dead
Re: "Skinnies"
Just make sure you take sharp corners slower. Not sure if your car is lowered, but you want to have the correct camber set. I have seen pics of Weld Prostars that cracked do to miss-use and poor alignment.
-91 Mustang Coupe Ex 4cyl car, built to the hilt. -99 F150. 3" lift, 35" Procomps, Dynomax exhaust
01-07-2004, 12:04 PM
AF - Advisor
Thanks for the heads up fellows. I really appreciate the help.
My car is lowered properly and I had an alignment done ... so I am assuming if I am only using these to go down the track I should be OK.
I am just just to a car that handles flawlessly ... so the change will be a bit disturbing.
01-08-2004, 09:33 AM
Back from the dead
Re: "Skinnies"
What do you plan on running for rims and tires?
01-08-2004, 09:50 AM
AF - Advisor
Weld Draglites 15 X 3.5
... I believe the tires are going to be Hoosiers.
My rears, I am using my 16" with BFG Drag Radials.
When money allows, I will get Draglites for the rear as well with a slick.
01-08-2004, 08:22 PM
Back from the dead
Re: "Skinnies"
Nice. The BFG's have great hook for a street legal tire, but tread life sucks, that's why I went with Nitto's. I too plan on getting draglites with slicks and skinnys as soon as I have the extra cash.
