Help celica issues
Toyota_ch1ck
01-04-2004, 04:12 PM
Help I think My celica is dieing.. I cant figure out what the heck it is.. :banghead:
Okay! She starts runs for 5 mins or so starts to studer, (idle bounses at/when studdering) then she dies. Sometimes after a while she will start back up, then do it again.. anyone know what this is.....Im going nuts :screwy: ... Please help thanx
illGT4
01-04-2004, 06:43 PM
You ever replace common parts such as plugs, wires, rotor, dizzy cap??????
Did you check the ECU for codes?
If you are not getting any codes, I would replace the above mentioned parts with TOYOTA brand parts. Their ignition components are equal to or superior than any company on the market.
(NGK plugs, Toyota cap, wires/leads, rotor).
Can't help much more without knowing more about your Celica. :(
regards...
chris
Toyota_ch1ck
01-04-2004, 11:51 PM
:smile: Thank you, but i think i got it figured I took apart the air filter and found it cloged with leafs :eek: not good.. And checked the fuel fiilter to find the previouse owner had never changed it... :rolleyes: so I changed it Cleaned out the leafs and shes puurrrrr in again :lol2: :thumbsup:
GearGrinderGTS
01-05-2004, 01:08 AM
Man, that happened to me before, I got an 85, and I ripped apart the Air cleaner to see what size Adapter i need, and when I put it back together and started it up, all i got was a constant rev... Almost made me cry. When I took it apart again I found a screw jammed in the butterfly going to the throttle body :banghead: . That was the worst 10 minutes of my life.
illGT4
01-05-2004, 03:43 AM
:) Glad your okay.
Talk to you later, Toyota Ch1ck
peace
chris
http://way.to/celica.gtfour
illGT4
01-05-2004, 03:51 AM
and change those ignition parts if you never have. You'll like it. Check out some copper plugs rather than platinum if you want the most performance. plats just last longer, regular cheap copper provide better spark.
NGK plugs, $1.00/ea.
Toyota wires, $55
Cap and rotor, $40?
good stuff to do... won't hurt to change as you found out about leaves and fuel filters :)
later,
Chris
