Doorpanel
95sportSOHC
01-04-2004, 02:47 AM
How do i get the doorpanel off of my 95 neon sport.....manual windows, power locks, and power mirrors. I'm trying to put aftermarket door speakers in. Thanx
specter
01-05-2004, 08:40 PM
the manual window cranks SHOULD just pull out i think, and then the panal would slide out (unless theres a few screws anchoring it down like underneath the dash
soul_sword34
01-06-2004, 01:01 AM
invest a few bucks in a Haynes manual at your local parts store and save yourself the mistakes. :2cents:
specter
01-06-2004, 04:21 AM
or that =D
jordaddy
01-06-2004, 10:51 PM
if its the same as my 2000 neon, you have to take off the crank, there is a weird lock clip that keeps the crank from falling off, use a thin peice of metal or a peice of cloth to fish it out from behind the crank, once you get that off, make sure you get all the screws out, then pull realy hard, it should snap off, its just like playin with legos! then you have to unhook the lock and door handle lines. thats it I think. good luck.
hookdupneon
01-14-2004, 08:12 PM
To remove the door panel use a phillips screwdirver and remove the screw in the door pull cup. Then remove the screw behind the door handle by pulling door handle forward and use a T20 star shaped bit to get it out. Next use a rag to remove the retaining clip on the window crank, slide the rag back and forth untill clip pops lose. Remove window crank. Use something to pry off the door panel now and pull it off. Remove the door handle linkage bar so the panel can fully come off.
95sportSOHC
01-14-2004, 11:30 PM
thanx people
