oil leak
unknownforever
01-03-2004, 09:27 PM
hey guys, anyone know where's the most common place to have a oil leak? My car seems to be having a oil leak.. I have a hond accord 96 EX V6. Thank You
BullShifter
01-04-2004, 12:04 AM
The most common oil leak on Honda's is normally from the drain plug - washer not replaced with last oil change.
Where does it seem to leaking - front, rear, right, left of engine bay?
HONDA_99
01-04-2004, 08:52 AM
5gen had recall on balancer shaft oil seal, did you get it fixed?
unknownforever
01-04-2004, 08:54 AM
it's coming for the front... I have just took a little closer look and you know the screw or what you call it when you change oil, you take that screw out and the oil filter so oil will come out...well that place seems to have oil around it and I think it's dropping from there....
BullShifter
01-04-2004, 04:33 PM
The oil drain plug, like I posted above. The washer should be replaced every oil change, it is an aluminum CRSUH washer.
Honda 99 - The balance shaft update was only for 4 bangers, correct? I'm starting to forget some of this stuff, haven't worked for Honda in 2 yrs & kinda miss that place.
HONDA_99
01-04-2004, 07:58 PM
:iceslolan
ajdragonf
01-09-2004, 03:28 PM
I seem to be having quite a large problem with oil coming out of my 94 accord ex manual 4cyl. I just noticed the leak right after I had got the oil changed about 5 days ago. I brought it back to them and they looked it over. No problems caused by the oil change. The oil seems to be coming from behind the engine block on the right side, middle of the block. Can anyone help me out. Will this be costly to fix?
unknownforever
01-09-2004, 04:01 PM
When they haven't change the oil, has it has the leak?
mgcatthew
01-09-2004, 07:56 PM
hey ajdragonf is it leaking near any pulleys?
