hydraulic clutch not grabbing
97h2accord
01-03-2004, 05:11 PM
i have a h22a in my accord and the engine revs fine but the tach is floating meaning the clutch is not clamping like it should any input would be greatly welcome i bled the hydraulic line before and it was fine but whenever i push it the clutch gets mushy again and does not want to grab
Maple50175
01-11-2004, 01:20 PM
Get a new Clutch
the_mad_scientist
01-11-2004, 06:03 PM
Bleeding the hydraulic line would have nothing to do with it. The only thing that the master cylinder (clutch master cylinder, that is) controls is the clutch release. It has very little to do with a slipping clutch, which sounds like your problem. If your master cylinder was leaking or low on fluid, it would just travel almost to the floor before disengaging. In your case, the only thing to do would be to replace the clutch with a new kit. It's either a slipping clutch or a warped pressure plate. When you go to replace the problem, it's best to replace all the clutch components. Once you learn what is involved in replacing the clutch and actually do it, you'll never want to do it again. It's that much of a pain. If you paid a mechanic to do it, it's going to cost a bunch. I would recommend that if you don't have the time/experience/tools to do it yourself. Good luck :D
