Turn Signal Trouble
Google
Web AF
golden-touch1
01-03-2004, 04:14 PM
All of a sudden my turn signal decided it would not flash to signal my turns. The light just stays on. I do not have any bulbs out, and the fuses are good. Any suggestions??
99ssconv
01-13-2004, 10:14 PM
yeah the year might help, wiggle the hazard switch and see if they start working again
golden-touch1
01-13-2004, 10:44 PM
The trouble with my turn signal was the brain was going bad in my Trailblazer - apparently this is a common problem. Luckily the repair was covered under warranty. Thanks for your suggestion though!
gnfreak
02-16-2004, 09:31 AM
do you happen to have any numbers for say a technical service bulletin?? my emergency flashers come on intermittenly with the left turn signal. thanks, keith
ScarabEpic22
03-05-2005, 05:14 AM
This exact problem happened to me, and i couldnt figure out the problem. I created a new post, and one person posted they needed a new turn signal multifunction lever. Hope this helps.
BlulytesTB
03-15-2005, 01:45 PM
I had the same trouble. I noticed that if I left my hazards on for more than 5 minutes, the relay contact got stuck. Luckily under warranty, but still an annoyance!
Google
Web AF
