headlamps and foglamps do not worklucyna 01-03-2004, 03:09 PM Hello, I own Ford 98 Explorer Sport, and the headlamps or foglamps are not working. I have checked the appropriate fuses, what can be the problem? Thanks! Lucy KATAZ 01-04-2004, 10:18 PM i Believe It Can Be 1 Of 2 Things, Either Your Headlamps & Fog Lamps Are Connected Through A In-line Fuse That Has Burned Out Or Your Headlamp Switch May Need Replacing, Now When You Turn On Your Headlamps Do Your Rear Night Lights Turn On? If Not Then Your Headlamp Switch Should Be Your Best Bet! But If They Do Turn On I Would Check And See If You Have A In-line Fuse That Has Burned, I Hope That May Be Of Some Help To You, Peace Automotive Network, Inc., Copyright ©2012
