Sensor reads bad, but checks okayCjparker 01-02-2004, 06:00 PM Our 1998 Avalon check engine is on. The code we get is PO135 and we checked the sensor out and it reads okay. The voltage is reading what it should read. What else can we check? REally don't want to replace Computer unit. HELP!!! 2SLOW2FURIOUS 01-06-2004, 01:46 AM This is 02 sensor code. how did you check the sensor?? with scanner or manually took out and ohm it??? if you have a scanner you can pin point it by watching the 02 sensor and see if it works correctly.. if not just replace it and clear codes... Automotive Network, Inc., Copyright ©2012
