Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 01-02-2004, 05:09 PM   #1
the_zogs
the_zogs Normal reputation
Question 1998 Suburban w/ catalyst efficiency failure
Has anyone had this problem? Could it be the O2 sensors? there are two seperate converters, is there any way to tell which one is bad or both maybe?
I had a muffler guy tell me he could remove the converters and put glass packs in but that would cause a O2 sensor problem wouldn't it? The check engine light would stay on right?
the_zogs is offline   Reply With Quote
Old 01-02-2004, 07:02 PM   #2
Bronco2
Bronco2 Normal reputation
Re: 1998 Suburban w/ catalyst efficiency failure
If you take the cats off you will have problem with the SES lite.The way the system works the ECM monitors the O2 sensors before and after the cat. When the cats are cold the ECM will see both before and after cat O2 sensors reading about the same-after the cats warm up the after cat O2 sensor should read "flat" voltage output. This is how the system monitors efficiency. A scan tool to watch the sensor output is probably the best way to see where your problem is. If you can't do this yourself take the truck to a shop-dealer may be your best bet for diagnosis. Then let the muffler guy replace the bad cat. This is a quick and dirty explanation,hope it helps
Bronco2 is offline   Reply With Quote
Old 01-03-2004, 07:59 PM   #3
fletch1024
fletch1024 Normal reputation
I own a 98 with 112K, and last week had the following code come up on the SES, "Catalyst System Efficiency Below Threshold (Bank 1)".
After talking to a buddy at the dealership he suggested running a "quality" fuel injector cleaner through the system. He thought it would clear in 3-5 driving cycles. I used a $5 bottle of injector cleaner from autozone, instead of the $.99 cheap stuff and sure enough after about 40 miles the light cleared on it's own.
Don't know if it's a similar issue, but thought I would mention it. Good luck.
fletch1024 is offline   Reply With Quote
Bookmarks
Google
Web AF
