93 dx coupe (b16a) vs 2003 spec v
crabby760
01-02-2004, 05:33 AM
i have a 93 dx coupe with b16a mtoor with intake/header/exhaust and mugen ecu and my friend has a 2003 nissan spec v with intake/header he's on 17's on im 13 inch stocks who dou u think would win in a 1/4 mile race were both decent drivers
crabby760
01-02-2004, 04:13 PM
Bump Bump Bump.....
Ricochet
01-02-2004, 04:22 PM
You will with a descent launch. Go race and let us know..
lewdaka03
01-03-2004, 12:00 AM
well this is what will happen... if you both launch good he will pull through 1st prolly half a car then by second youll be neck and neck... and by third you should be half a car ahead. then by fourth youl pull to about 1 car... then basically stay that way with him maybe gainin back a half in fifth... But you never know... JUS RACE AND TELL US WUT HAPPENED DAMN IT!!!!!! :evillol:
pikkagtr
01-03-2004, 07:10 AM
yes the only way to find out is race
i always wanted to know how a sepc v would fair
carrrnuttt
01-03-2004, 11:50 AM
The way I see it is this:
I've raced a swapped EX before in my "Classic" SE-R, and beat it by three cars.
I know that your DX should be lighter than the EX, so I should mention that one of the two b16 cars that beat me in town was a light-as-hell CRX with an I/H/E b16...and he beat me by one car (my front-bumper even with his back-bumper).
I have also raced a couple of stock SpecVs, and both times I have raced them, we were dead-even, with one pulling maybe a fender, depending on how fast we shifted.
I've run a best of 15.0 using a G-Tech, with a spinning launch.
Don't count on top-end either, as most these races reached into 4th gear.
I say it'll be close...too close to tell, especially not knowing you guys' skills.
Just race and find-out.
crabby760
01-03-2004, 02:55 PM
WE RACED LAST NITE
ok off the take off were even sort of my 13's are spinning like a mothafooka end of 1st he's a little ahead of me shift to 2nd boom i pick up a little on him by end of 2nd gear i have him by a fender bam 3rd gear we are same 1 fender ahead of him but by the end of 3rd gear i pull half a car i was shifting at 9,000 rpms
crabby760
01-25-2004, 06:53 PM
we raced again this time i had no wheel spin i jumped him like 1 car in 1st gear then pulled more in 2nd gear by the end of 3rd i had like 2 cars on him that was a week ago now he added a exhuast system and some axel balance transfer kit? something like that i dunno what it is but do you think with those extra mods he will beat me now ? i had 2 cars on him when he had intake/header/nocat now he'll have intake/header/nocat/fullexhuast/balance axel transfer kit?
YOUNGSTER
01-25-2004, 11:55 PM
hes gonna beat you if he drives good cause if your saying what i think your saying that he got his balance shaft remove which does wounders in those motors vq's but you never know
crabby760
01-26-2004, 12:00 AM
damn what does the balance shaft removal actually do for his car can someone tell me please and how many car lenghts would he gain from this mod im hoping to take off my cat also by friday so i'll be running cold air intake/dc header/ no cat/ full exhaust and the mugen chip let me know thanks
carrrnuttt
01-26-2004, 12:24 AM
It's estimated to add up to 25WHP on those cars.
crabby760
01-26-2004, 12:36 AM
so if i beat him by 2 cars before he added that balance shaft removal im basically gonna get smoked now?
YOUNGSTER
01-26-2004, 03:44 AM
i know one thing it should be a bad ass race :naughty:
wperdigon
09-24-2004, 07:03 PM
Hello,
I'm a Spec V owner - and I'm sorry, but I have to disagree on your race about being dead even.
First, a few reason to support my argument -
A modded spec v with intake and header is putting down about 160-166 horses or so depending on the weather. The thing with this is the torque - he is making almost 170lbs torque where your making what, 130 or so - there is no way that your civic, even with reving to 9 grand is going to out drive or be faster then the spec -
secondly, depending on the modifications done to his car, the balance shaft removal frees up between 6-10 horses and if he does the knock sensor, then he is looking at another 4-6 also.
the balance shaft is a component in the engine that basically is a harmonic balancing tool used to reduce vibration in the engine. Since the 2.5 is also offered in the Altima, Nissan needed to make the altima a comfortable car to drive in thus the balance shaft is added - since it is chain driven, it robs horses from the car and also causes oil frothing in the oil pan. Removing it from the car causes more vibration but then frees power because it is not on the chain anymore.
I have a spec and I have intake, headers, cams, exhaust, and motor mounts and i race against b16's all the time - no way guy -
SiXPuSHA
09-24-2004, 07:18 PM
You must hate torque :eek7: . Unless you can get your flywheel machined right fast or pick up a lightweight aluminum job, you're going to struggle...
wperdigon
09-24-2004, 08:32 PM
why would i hate torque? i mean, i have no problems with it - it's just fine with me, it's what pulls me in the low end - i trade good torque for hp simply because that torque is whats pulling the car
TatII
09-25-2004, 01:01 AM
hp takes over from where torque leaves off at 5252 rpm.
Ricochet
09-25-2004, 02:50 AM
Good job bringing back a 9 month old thread to argue with people that aren't even on the board anymore :rolleyes:
carrrnuttt
09-25-2004, 04:36 AM
Hello,
Oh jeesh, let it go man. Go find a fucking race of your own and prove him wrong that way.
Locked.
