car quits
ford555
01-01-2004, 01:32 PM
i have 9o cutlass that just quits when your driving but will restart right away but will not take gas it just bogs out but after awhile it work fine .sometimes it works good for week other times it will do it 4 times in a day it does not show any codes
ford555
01-09-2004, 10:40 AM
Bump.
The car also has new crankshaft position sensor, and a new ignition module.
bluecalais
07-05-2004, 04:48 PM
Ok, it kind of sounds like you're experiencing a problem that occured with my '89 Calais a few years ago, which I had fixed. You weren't very specific in your description of the problem, so I'll tell you what I experienced and you can compare...
Whenever I drove at highway speeds for more than about 15 minutes, my car would die at the first complete stop I would make. However, driving around town at normal town speeds, I had no problem. Only after driving fast would the car die when I'd make my first stop. When I would try to restart it, the engine would turn, but like you said, would "bog out." If I just sat in my car and waited like, 20 minutes and THEN retried starting it, the car would be fine and I'd be on my way. It was VERY annoying, so I finally took it in to get fixed. The mechanic said he replaced a cylinoid (spelling?), and that's all I know. I DO know, however, that it cost me about $400 to fix. I hope this helps...
Slade901
07-07-2004, 03:05 PM
Check your CTS (Coolant Temperature Sensor). If the CTS is bad, either it gives out a too cold signal or too hot signal to the computer.
If it is stuck in too hot, it signals the computer and in turn it will immediately close the fuel injectors and not stay long enough.
If it is stuck in too cold, it signals the computer and in turn it will immediately open the fuel injectors for a long time and probably flood the engine.
During initial startup (cold engine), the Normal CTS sends a cold signal to the computer to open the fuel injectors longer and then gradually returns the fuel injectors to normal operation as the temperature rises.
The Fuel Pressure Regulator has a diaphragm inside and if that diaphragm ruptures, excess fuel is sucked into the Fuel Pressure Regulator vacuum hose and into the intake. Check the Fuel Pressure Regulator vacuum hose for any sign of fuel inside the vacuum hose (do it after the engine has been started for a while).
Like what they say, it is probably the TCC solenoid (Torque Clutch Converter solenoid). It is suppose to lock up when driving at a cruising speed to give you good gas mileage but then the TCC is suppose to disengaged when you slow down. However, bad TCC will not disenaged when slowing down (it's like leaving the gear on 4th on manual transmission while slowing down and it will surely kills the engine) and so the engine dies when approaching a stop sign because the automatic transmission is still on the high gear and still the TCC solenoid has not disengaged it. Simple solution is to just disconnect the TCC solenoid wire connector but then you would not get a good mileage when cruising.
Also, I did experience the same thing on my car and noticed that coolant reservoir spill excess coolant out of the top cover and squirts down where the Ignition Coil and Ignition Control Module is located. The coolant reservoir has a drain hose attached to the top cover of the coolant reservoir but for some reason the excess coolant came out of around the top cover and not on the drain tube. I have sealed the top cover so the excess coolant comes out of the drain tube which sits on top of the top cover.
spidervirus
07-14-2004, 07:39 PM
i have a 94 and the same thing happened to me i changed my plugs and wires and it cleared up...
